Garnification said:My question is can the two be hooked together by just matching up hots, neutral, and ground?
No.
Cheers
kenny
velvetfoot said:JD, I think the breaker 30 amps, 240 volts. The 39 amps is max at startup. We used it today again for showers. You really can notice on the 7500 watt generator when the well pump comes on!
Time Warner won't run cable out to where we are and we had looked into satellite, like HughesNet. Turns out there is a Sprint tower very near us and the wireless broadband is great!
jdemaris said:stee6043 said:This spring instead of dropping the $70 on making my own ten foot long 30 amp cord to connect the 30 amp plug from the generator to my breaker I tried to do the male-to-male plug idea to get my well pump running just long enough to take a shower. Did not work. You just can't get enough juice through a standard extension cord to support a typical well pump. That hog draws some juice.
I don't know your pump-motor details, but I'll say this. Years ago, before I had a big PTO generator and solar - I did the following and it worked just fine. Cheap Homelite 4000 watt generator with an 8 horse Briggs and a single, 240 volt, 20 amp outlet. I made an extension cord with the 20 amp/240 volt male-plug on one end, and a 50 amp/240 male plug on the other. When power was out - I backfed it into an electric stove outlet - along with turing off the main breaker, and also all the other breakers except my well pump. Well is 3/4 horsepower, 240 volts. Worked just fine. Did this many times over the years when power was out. Got my well-water pumped up- then shut off that breaker, turning on the furnace breaker and let the oil hot-air furnace run a while. Then, shut off that breaker and let the fridge and lights run. Worked out 100% fine, just required a lot of running down the basement and playing with breakers. And that was with a cheap 8 horse, $375 generator - rated 4400 watts surge, and 4000 watts full time. Has dual 15 amp 120 VAC outlets and one 20 amp 240 volt outlet.
I'll add that saying you "can't get the juice" though an extension cord is incorrect. You just have to use the correct size wire -regardless if it's in the wall, in the ground, or used as a portable cord.
seige101 said:As i said in the other thread in the pellet forum. Please buy the manual transfer switch kit. It's only $300 bucks at depot
Gooserider said:I.
We need juice for several small things scattered around the house on different circuits (fridge, freezer, sump pump, GF's CPAP machine, etc. all on different circuits) and we have a sub-panel for some of them so the Home Depot box that taps into the existing panel doesn't work.
Gooserider
struggle said:Here is what I did. I got a dummy meter base and cut the power cross over tabs far apart so power does not go through the dummy base and wired my generator cord into the power to house only side of my outside box. I have to clamp onto the copper ground wire via vise-grips.
If power goes out for a long time all I have to do is pull the meter out and install my dummy meter in place. It is completely disconnected from the grid and it powers my whole house except for what I shut off in the panel like things that would over load the generator.
I have used it a couple of times with a 5500 watt troy built generator and it works like a charm.
When the power comes back on I just pull the dummy out and put the normal meter back in.
In 11 years I have lived hear we only had one time we were out of power for more than 3 hours. If I lived somewhere I had multiple power outages I would put in a transfer switch with an outside plug for the generator put as it is we thankfully do not lose power often. My whole neighbor hood is underground serviced so it takes a large transmission line to go down to shut us off.
Gooserider said:A good idea in some cases, certainly it solves the "disconnecting from the main" problem quite emphatically... The problem with it though is that in many places (like ours) the electric company puts a seal on the meter mount, such that you can't unplug the meter w/o breaking the seal - and I hear that they get downright obnoxious when the seal is broken....
Gooserider
struggle said:I have done it a couple of times and they just put a new seal back on it and never say anything. They cannot tell you you cannot access your box on your house. At least in my parts they leave us alone.
Highbeam said:Sure, you pay for it. Just like you pay for the new transformer which you don't own. At least that's the way our power company does it. I had to cut my meter seal when I removed the meter for a new service panel installation. We just did it. I had the power company out to fix a bad connection on their side of the meter and asked them to put on a new one. They did it without any gripes.
seige101 said:The kit i am referring to is essentially a subpanel that installs next to your existing panel. It also includes, the wire from the generator to an inlet box usually mounted in the outside of the house, and all the related wiring. http://www.electricgeneratorsdirect...tag&utm_source=nextag&utm_medium=shop+portals Thats the $300 kit i recommend
Highbeam said:Struggle: That's a truly safe setup except for the time when you need to reinstall the meter into the live meter base after the power comes on. Anytime those sockets are exposed there is risk. Just like removing the panel covers, exposed hot connections are risky.
