Is the oil burner running and maintaining the 69 in the rest of the house?
Grimrot,
I have a new Defiant in a similiar type of room, 10 or 12 foot panes of glass,cathedral ceilings with a lolft, etc. You must be losing A LOT of heat because at 650 on my Defiant it is between 70 and 75 throughout the house without any other heat sources. We got some of those insulated shades a few years ago and they helped us out quite a bit - my only regret on them is that I should have purchased the motorized retractors). I would try temporarily covering those windows and see if they are the culprit.
Hi Oslo - yes I have ceiling fans that I can reverse. I haven't got to that quite yet but it's on my list. I bought this thinking it was overkill for the room and it's not even making a dent. The specs say it's good for up to 2400 square feet.
I'll bet if you take the temperature up near the ceiling it will be over 90F up there.
Also, is this a warm air heating system or a hot water system with a blower?
The oil heating system is forced hot water.
Are there radiators (baseboard) or fan blown heat exchangers?
Is your Oil Heat still turning on? or is the stove completely taking over? if your stove is taking over and you can keep the house at 70, thats not that bad.
The oil heat gets it up to 69. Anything higher then that is due to the stove. Once it gets beyond 69 that zone stops calling for heat.
Have you measured the temp up there yet?i bet alot of your heat is up in the cathedral.
