Hi All
Apologies now as I am an absolute rookie here. I grew up with a woodburning fireplace in New England and so have a very romantic view of them. I just moved to Missouri and bought my first house and it has an old fireplace from 1984. My husband and I would LOVE to have a function wood burning fireplace but we have a situation and would very much value any expert advice from you all. He is Australian and excited about winter and a fireplace
The situation:
- The old fireplace was converted to gas by previous owner and isn't working properly - I am too scared to mess around with the gas to try to get it to work
- We want to convert back to wood burning for warmth (in addition to our furnace) and ambiance for our ground level 1500 sq ft and if it can help provide heat to the upstairs, even better.
- I had the fireplace professionally inspected and these are the notes from his assessment: 1- Firebox has rust damage. Fireplace has a vent less gas log set which goes against manufacturer instructions. Firebox dome appears to be compromised, it shows signs of overheating. 2.- Damper is functional. 3.- Flue liner - chamber transition has a gap around. 4.- Roof stack is in good condition. FIREPLACE ISMNOT LONGER SAFE TO USE, REPLACEMENT IS RECOMMENDED
- So we need to replace the fireplace box which will require removing the drywall in the room behind the fireplace as there is a large brick wall in front of the fireplace.
- My crazy engineer dad felt that it might be possible to cut out the box, measure matching pieces and weld a new box in place to avoid having to tear through a wall. I got excited about this idea and then realized it might not be safe or up to code.
- The frame of the fireplace which I can see is 43in wide and 31in tall (no idea how big behind the brick) and the box part is about 29in x 20in. Not sure how much this matters
Our goals:
- Install a new fireplace box, remove gas, and repair gap around flue liner.
- We are hoping to keep project costs below $5k if possible and are interested in value for money for renos. If it is really worth it we can go higher in budget.
- Would be good to use a tax credit if it makes sense
- Ideally the new set up would be up to code
- We plan to sit in front of the fire in winter so it should look nice
Questions:
- What should be my first step? How to pick a good contractor to help?
- Any recommendations on the best fireplace to buy for this situation considering value for money?
Many thanks in advance for the help and suggestions!!
The situation:
Our goals:
Questions:
