So my buddy tiled his down stairs bathroom. He went and re installed the toilet, and now it rocks. How can we fix this situation?
FatttFire said:So my buddy tiled his down stairs bathroom. He went and re installed the toilet, and now it rocks. How can we fix this situation?
FatttFire said:Sounds good. I will tell him to use the plastic shims...................... even though I know I will be doing it!
GVA said:I heard some pro's used plaster of paris under the toilet.. and it gave a smooth look too..
Treebeard said:GVA said:I heard some pro's used plaster of paris under the toilet.. and it gave a smooth look too..
I saw a plumber do this on THIS OLD HOUSE and it work real well. He lifted the toilet up off the floor and laid down a good pile of mud(the kind used for gyproc walls) and being careful not to block the drain pipe, he put the toilet back in place. Then he push it down on the floor so as the extra mud squeezed out. A little clean up and tightening of the bolts and it was finished. This was on a new install and he recommended that the mud be allowed to cure before using. He said he used mud because if ever you needed to replace the toilet or the wax ring it would come up easier than if you used tile grout. It made sense to me.![]()
SmokinJoe said:Treebeard said:GVA said:I heard some pro's used plaster of paris under the toilet.. and it gave a smooth look too..
If the ring leaks the mud will form a seal and make the situation worse that if you had not sealed the toilet to the floor.
Toilets were not meant to be caulked or grouted, and certainly not drywall mudded, to the floor.
Don't believe everything you see on T.V.
J.P.
