The only reason I see to rip out old fiberglass batts in the attic would be to make air sealing easier/better since you can see everything all at once. Otherwise you just pull back one batt, seal, replace…
I suppose if you have low eaves with little room to add blown-in on top then it could make sense to pull batts out there.
In other words if I you're cold just put on a sweater. No need to take your shirt off first.
