Replacing Wood Stove with Pellet
jfhall27
3
New Hampshire
I'm hoping to replace my existing wood stove (in my basement) with a pellet stove. The existing wood stove is venting into a clay lined (6x12 I think) masonry chimney and I'm having a tough time with the local advice that I'm getting. The guys at the local stores that sell Harman and other brands say this is easy and can be connected right up - but most internet research says to put in a liner. My rise would be about 20-25 feet.
Second part is on the inside. I have a brick hearth and a 6" round opening. How would I go about finishing that off if I lined it, or what would I need to use for an adapter if it's acceptable to direct vent? The attached pics are of my existing setup.
Thank you,
John
[Hearth.com] Replacing Wood Stove with Pellet
Welcome to the forum!
I'm no expert on clay liners but if it was safe for a wood stove
then a pellet stove is good to go as far as I am concerned. Just
check with your building inspector of the Fire department maybe
even your insurance company. But I will bet that they don't know
Reactions: Bob Sorjanen
Thank for the advice. I called the building inspector today and he indicated it was fine to vent directly into the chimney so that's good news. Any idea where I can find the necessary adapter to go from a 3" PVL to the single wall stove pipe that my wood stove is using. I've been searching for a while now without much luck.
Thanks
If your wood stove used 6 in single wall into the chimney
I would suggest that you get a 6 to3 adaptor and use pellet
vent as needed to the stove
