Let me apologize in advanced for the wall of text.
I want to replace my old fireplace. It appears to be a Superior SP38, but I'm not 100% sure about that. The only number I could find was on the handle, and beyond that my internet sleuthing skills have returned nothing. As a fireplace goes, it seems pretty decent. I am able to heat that room to 75* and that side of the house to 70* with a few box fans to circulate air, but it uses a lot of wood and won't burn for more then a couple hours without additions. There is no damper or air control of any kind.
I've been considering a stove for a while to help reduce electric heating costs, which during these months is running around $500 a month. I have a heat pump and keep the house at 65*. Natural gas or propane is not an option. I have decent insulation in the attic, newer windows, and feel the house is pretty tight. My home is around 3200sq feet and is a tri-level with a very non-open floor plan. I'm considering both the Drolet Escape 1400i, because it is cheap, and the Buck Stove Model 91 because there is a very reputable dealer 5 miles away. Obviously I have concerns about one being too small (in which case I could re-purpose it to another part of the house later on) and the other too large (eh, the room gets hot).
I pulled the lower grill off it this evening because I can feel a rush of cold air coming in constantly. My initial thought was that the cold air was coming down the chimney (it's a 8" double wall air insulated pipe, in masonry, on the exterior of the house) and spilling out the bottom of the fireplace. However, after removing the grill I found several holes in the masonry where the air was pouring through. One of them was quite large and I can see that the fireplace is not resting on solid brick, but on several layers of concrete block and wood. My guess is, if I were to remove the fireplace I would find a large unfinished masonry hole...not a proper masonry fireplace but no combustible framing either.
So, I feel like I can't really put it off anymore and I should have jumped on the tax credit sooner. Regardless, something has to be done about the amount of air coming in, which means removing the fireplace anyway. I'm thinking the following...
1. I will have to replace the chimney pipe. I'd run 8" and adapt down to 6" if necessary, but this would give me the most options. The current pipe has a great draft and I would use it if I could.
2. Assuming there is just unfinished masonry back there I realize I will have to finish it off using some combination of steel studs(?) or brick, cement board, and probably slate (left over from another project).
3. I'll most likely have to extend the hearth a bit.
Here's a pic of the entire fireplace.
And a pic of one of the holes underneath. You can see the cement block and wood under the fireplace.
Here is a pic of the outside wall (bad cell phone cam pic). The bump out is 18" deep and 48" wide.
I would appreciate any advice, input, or criticisms. I'm a fairly experienced DIYer and feel pretty comfortable with the task...besides, I can always come back and ask for more help and information, right? Thanks!
Jeremy
Jeremy
