Replacing damper handle/lever
sbtm
4
CO
I just bought a 1960's house with a wood burning fireplace. The previous owners had fires all the time, but the damper arm was removed and the damper plate was flopped backwards and always open.
I am looking for what type of damper lever is required, below are pictures of the damper. The brackets are on the right hand side of the trapezoidal damper. The fixed bracket has the screw sitting in it (screw is not part of the mechanism obviously) is on the bottom (back wall of fire box, right below the throat.)
I have also attached a pic of damper levers sold by Rockford Chimney Supply. The "Right hand style" jumped out at me but i have no idea.
Thanks
Dylan
Replacing damper handle/lever Replacing damper handle/lever Replacing damper handle/lever
To be clear, the damper is hinged at the bottom, the opening would be at the top of both photos
None of those posted are right those are for traditional cast dampers used in masonry fireplaces. You have a heat form the handle will be specific to the brand you have. Try getting a sweep out they may be able to locate one or have one made
The fire box is a steel lined, but the rest is brick. I looked all over, didn't see any branding. The operation I am looking for is simple enough, all the way open or all the way closed. I may end up just making something myself
Thanks
Dylan
Thanks
Dylan
Yes i know what it is. It is called a heat form. The handle for yours is usually a peice of about 1/8"flat stock with a hole in the top and a slot in the bottom. It would not be hard to make one especially if you had one to take measurments off of. Which a sweep should be able to find.
Reactions: sbtm
