replacement windows
blacktail
1,419
Western WA
I'm getting new windows put in my house in the near future. Finally time to dump the Dr appt aluminum frames! I've got a few estimates for Coeur d'Alene, Cascade, and Milgard vinyl frame windows. I'm still waiting on an estimate from one more contractor but they also deal with Cascade and Milgard.
In my brief searches online so far, it looks like Cascade windows are considered the lowest quality, and the price I was quoted reflects that.
Any input on what's good or bad with these options?
Just checked my email and got the other estimate. I was incorrect in the brand they offered. They wrote the estimate for Lindsay windows. I'll do more googling but what I've read so far says they are decent for the price. This last estimate was slightly higher than the lowest bid I got, and that lowest bid was for Cascades.
I like the company that gave the last bid. It's a small family company consisting of only the owner and his two sons. They've been in business a long time and they were the only company to stress the quality of their installation work, including details about how they'd handle the trim work.
Milgard is a local company to us in the NW. I had my single pane aluminums changed to replacement (finless) vinyl double pane and it turned out great. They just screw them into the rough opening after having them custom made to fit. Big improvement in comfort, noise, and aesthetics. Quick job too. They actually crushed/ripped/yanked out the old aluminum framed windows.
Can't offer any insight on brands but I can say that wood frames/ sashes and or Fiberglass systems. suffer the least amount of expansion contraction. Fiberglass is all most the same rate as wood where as most everything else has considerably more movement- which down the road a piece results in air leaks. The other info I came across is that solid vinyl assemblies shrink with age. I have done 2 homes with replacement wooden double hung sash assemblies ( alum. clad to the out side) with no regrets ( neither place required complete frame replacement).
Are you getting New or Replacement Windows?
The company I liked best specified that they use windows with the nail fins and additional trim work, and they emphasized the benefits of doing it that way. The other companies didn't say anything about how it would be done.
I personally don't care for replacement windows. basically all you are doing is replacing the glass. If you have any leakage between the frames and the walls it is still going to be there.
Greg
Reactions: Don2222
Yes the nail flanges (fins) that seal up really well come on most new windows. The best way to go!
Seems to be a bit of confusion here. You can buy new windows with or without a nail fin. The full frame and everything is new. If you get the fin then the window is face nailed to the sheathing over your rough opening and then you fill in the gaps between the frame and the wood framing with something to seal it. The finless windows are installed like a door, to the actual inside of the rough opening. You then fill the same gap with something to seal it. Both are perfectly acceptable but the fin requires a lot more exterior trim work on a retrofit. Also, you can customize the reveal with a finless window so that you can shove the new window right up to the interior sheetrock and sill. Not so with the fin.
I have seen the fins cutoff on site to make installation easier. Heard finned windows called "new work" and finless called "old work" just like electrical boxes.
If you bust the glass with a rock, the actual double pane glass part can often be popped out and replaced but that's not what we're talking about here at all.
Thanks Highbeam, I was going to mention the same thing.
Reactions: Highbeam
Was a Gen Contractor for many years and Milgard was my favorite.
You are absolutely right. But I think replacement windows get a bad wrap because many contractors simply pull the old sashes out and insert the new window into the old frame without doing anything to seal that frame up. This means there can still be massive ammounts of air leakage. But done right there is nothing wrong with replacement windows at all.
Out here in the west we call them retro windows. One of the coolest things about retros was you could pay your crew $4.00 per hour and no one had to own a pair of work boots. 8 guys running around like chickens with their heads cut off and they could still get a 2000 sq ft house done in six hours. Super high quality. Hard to compete with the Home Depot parking lot crews.
X
x2
I like the nail Flange or fin, sure it is a lot more work but assures no water leakage and a good seal. IHMO
I removed all the old windows and their frames and then replaced them with brand new Anderson Windows with the nailing Flange. Still I had to use window foam to put in under the inside trim between the new window and the jack studs and top header and bottom studs. Hopefully they are sealed up enough?
See my pics here
https://www.hearth.com/talk/threads...new-construction-windows.127643/#post-1717852
Reactions: Jazzberry
You did good. Only bad thing about Anderson is the price. Killer windows if you can afford them.
Here are some 2019 prices for Anderson double hung windows.
Are these very high?
What prices have you seen for other double hung windows?
  • replacement windows
Always gets me that solar panels are cheaper than windows. on square foot basis. One of these years they will come up with a cost effective coating on the outside of the window that will turn it into solar panel.
My brother is getting ready to build a house and he went to two different building suppliers for catalogs with sizing. Both places told him all windows are custom these days, just give them an size and they will build them. Sure doesnt make sense that they cant fill a warehouse full of stock sizes for lower unit cost.
You get what you pay for. My Pella windows are 15-20 yrs old and need replacing, they never did seal 100%. Replacing with Andersons one at a time.
In my experience Anderson's only last about 25yrs.
I been out of the game for 12 to 13 years now but Anderson have always been at the top of the heap for cost and quality. Pella always seemed like a quality window for the price. I really liked their sliding glass doors. One of the reasons I liked Milgard so much was when a customer called me a year or two after the install with a problem I would call Milgard and within a few days they would go to the site make my customers extremely happy. When I called to check up on them the customers usually told me what a great service they received from Milgard. Unbelievable customer service.
I first put vinyl window in a house in the very early 80's. I cannot remember the brand. About 11 years ago, I put vinyl windows in my neighbor's house. He was cheap and the windows showed it. I have a bit of experience as a DIY window replacer.
Nine years ago I put Cascade in this house. I had an issue with the mechanism that guides the window up and down. Cascade said they had gotten a defective bunch from their supplier and were here within a very short time to replace the mechanism in every window. No other issues.
So, I put them in my rental. No problems at all.
The house we are building has Cascade windows in it. I ordered their top of the line windows. Every contractor that has seen them raves on them.
I put Milguard in a house about 15 years ago. They were great, but when I went to purchase them for this house the cost staggered me. At that time the lumber yard recommended the Cascade. I'm glad they did.
For the place we are building, I ordered the windows in three sets as we worked through the different phases of remodeling and adding on, so I do not have and accurate total in my head, but I spent about 10-11K delivered to site. Milguard would have been about another 6k.
I can assure you that had I experienced any problems with Cascade beyound the defective mechanisms, I would not have continued to order them. Their prompt attention to that issue influenced my decision to purchase them again.
How you install the window is as important has the window itself. You defeat the purpose with a poor install.
In some case,s i order single hung windows. Zero leakage in the top window. Especially if your doing all first floor installations so cleaning is a non issue. Plus the window is rock solid during installation.
I have had to repair Anderson's over the years on occasions and a major plus is they stock many wear components for many years. I have bought parts for 40 year old Anderson's which is something not a lot of companies can or will do. Its not an easy process as they want to make sure you get the exact right part. I even converted over a fixed glass window to a crank out casement at one point by buying all the hardware. Mine are 30 years old and in great shape except for dumb stuff I did. The problem I expect is they may be too well built for a typical homeowner or builder who have a very low likelihood of staying in a house for more than 10 years. I have not had to order parts for Marvin's but have found that they are high quality. The Anderson Renewal windows that I have seen are well built but the business model of only selling through authorized installers means no DIY so anyone using them has to hope the installer does a good job.
First thing I learned on installing windows is the installation is crucial to the long term performance and its hard to do those details on a window replacement. Flashing frequently ends up being replaced with "goop" and "goop" usually is not a long term solution.
Glass is glass is glass. Coatings on the glass can change, as far as I know there is only a few different makers. The seals between the glass are important, but again there are really only a few different suppliers. The frame is what it all comes down to as far as quality. How much vinyl is inside the frame is what makes a difference. Good windows look like a "find your way out maze" like on a kids menu. This adds strength. The highest quality vinyl windows even fill the frame with foam adding more strength and R value.
Windows of lesser quality (lighter frame) will be prone to more movement, sagging,.... This causes operating problems. Anderson being a wood clad window makes it a strong window, the trade-off is the cost of cladding with aluminum on the outside by the manufacturer. Also the cost of painting/staining the interior wood side.
When comparing windows that's the details, glass seal, strength in the frames, and the noted important thing is service. If you have a issue will they stand behind you and their product.
As far as nail fin or no nail fin...it's purpose is for a quicker install in new construction. You just nail the fin and shim the frame from the inside. Without a nail fin you have to predrill the frame and install a screw to hold the window.
You must seal both types from the outside regardless. The nailing fin doesn't do any better job at that then a window without one.
Nail flange (new construction) is better 99.9% of the time. Its not unusual to find retro windows glued on to the existing window frame with 2 screws and double sided tape. And a 3 to 6 inch border trim of vinyl glued around the window is real tacky. I think in my area most of the retro installers hide their own easter eggs.
Reactions: Don2222
