First post here but I've been browsing the forums for some time now. I've really enjoyed the knowledge I've gained from these forums so far.
We moved into a new house in July and it had this old black bart 2 insert. We used it through Nov-Dec when we realized that it was a real wood hog. We are supplementing with wood heat since our house has electric baseboards. The old insert heated well since we have really good airflow throughout our lower level but the wood consumption was crazy.
After doing research I finally decided on the Regency i3100 and my local fireplace store had the floor model on sale so I jumped on it. My total for insert, new liner, and install was $3960.
So far we are loving it and the folks at the store have been very helpful. The only issue we have had is with the third air tube. Keeps falling out so I came up with a fix that seems to be working well (last pic below).
Old Black Bart 2.
![Replaced black bart 2 with regency i3100 Replaced black bart 2 with regency i3100](https://www.hearth.com/talk/data/attachments/193/193147-204bcda192821f13b69481a4f7741f95.jpg)
New i3100.
![Replaced black bart 2 with regency i3100 Replaced black bart 2 with regency i3100](https://www.hearth.com/talk/data/attachments/193/193148-e1d32930ba1b39d11b89599416a59df3.jpg)
First fire.
![Replaced black bart 2 with regency i3100 Replaced black bart 2 with regency i3100](https://www.hearth.com/talk/data/attachments/193/193149-71055c02397b2ded6588fd244ae20ef3.jpg)
Preventing air tube from falling out by using a stainless steel hose clamp as a stopper. Seems to work so far, just have to make sure it stays tight. I situated it so it doesn't interfere with the baffle.
![Replaced black bart 2 with regency i3100 Replaced black bart 2 with regency i3100](https://www.hearth.com/talk/data/attachments/193/193150-c52655892e5707ffbc9f7f45653f62e7.jpg)
Burn times have been really good. I can fully load it up at night and have a nice bed of coals in the morning. This was one of our main goals.
One thing I wonder is why the manual says not to run the fan with the airflow set below half? Would that seriously hurt it? I'd really like to have the fan on low pushing heat out and being able to set the airflow down 3/4 closed to burn even slower overnight. That's what we did with the black bart.
I have a thermometer coming (condar medallion) today. I see that some people put it on the front in the right corner but also see some in other locations across the front above the door. So far I've read the higher temps with my ir gun in the middle above the door and a few spots to the left and right of that. The corners seem cooler. I'll have to search more on that.
Old Black Bart 2.
New i3100.
First fire.
