Hello everyone.
My wife and I are purchasing a home next month that has a wood burning Heatilator EC42 factory fireplace in it.
We want to be able to install some kind of wood burning unit that will supplement the 1800-2000 square feet of living space in the home (currently heated with propane).
After doing hours of reading online, I'm not convinced on what we should do.
The Heatilator manual shows the use of double walled 8inch pipe UL 127 which i understand to be rated for lower temperatures, so my thought was to drop a 6 inch chimney liner down it and select a proper fireplace or insert.
http://hearthnhome.com/downloads/installmanuals/17339.pdf
Put after reading about inserts, I'm don't know if they have to be used with masonry fireplaces only. Then I started reading about Zero Clearance fireplaces and now I'm totally lost.
There must be thousands of houses with this same exact set up, but I can't find a definitive path to quality heat!
I'm attaching a picture of the current fireplace for what it's worth.
Any thoughts or ideas of how I can fit/replace a new heat source that would actually save me some money?
Mike
Mike
