quick question-
With the up and down temps in MI right now, I recently found that I can shut down my outdoor corn boiler for 2-3 days, then fire it back up, then shutdown, etc.. and save about 50% in corn over holding steady temp when no heat is needed. It takes about 25 minutes to get back to temp after a restart, so not too long.
My question: Is this a good way to rust out the firebox? I don't see anything about this in the manual, but I know I've seen authors here warn about running a boiler at low temp. Is frequent startup/shutdown basically the same as running at low temp in terms of rust risk?
Thanks!
Thanks!
