The time has come to remodel our family room and the first thing we need to improve is the builder grade masonry fireplace. Our goal is to create a single main focal point of the fireplace wall, instead of our current setup which has a second focal point of the TV mounted on an adjoining wall.
Objectives:
Fix/replace cracked hearth
Reduce draftiness
Install TV above mantle at a comfortable height
Current Plan:
Totally renovate, hearth, surrounds and mantel
Install a gas insert
Our understanding is that if we move to a gas insert that we could potentially lower the mantel height by as much as 20" from where it is today. We probably wouldn't go that far, but a lower height will certainly help with the TV viewing angle.
Question:
What should we expect to find behind the granite of the raised hearth extension? Would it be hollow? Cinder blocks? Concrete?
Our thought is that just lowering a mantle would look really weird. While we cannot (easily) lower the fireplace opening since it's masonry, we thought that replacing the raised hearth with one level to the floor would help keep proportions for the mantle in better balance. This would leave us with a fireplace "floating" 11" above the floor. From photos we've seen, we feel we can design the surrounds and mantle in a way where if wouldn't look weird.
Are there some other factors that we need to consider? Have any of you done or seen a similar renovation?
Some measurements:
Fireplace front opening width: 41 3/4”
Fireplace front opening height: 33”
Width at the back of fireplace: 21 1/2”
Fireplace depth: 20-1/4”
Width of hearth: 68”
Height of hearth extension: 11"
Depth of hearth extension: 19-1/2”
![Renovating Builder Grade Fireplace Renovating Builder Grade Fireplace](https://www.hearth.com/talk/data/attachments/233/233705-c7c71f20ffbefe76294fa4ae3a7e6efb.jpg)
Thank you,
B34N
Objectives:
Reduce draftiness
Current Plan:
Question:
Some measurements:
Thank you,
B34N
