We do have a member from southern florida (Where2) with lots of solar panels ,anyone heard from him???????????????
No, you haven't heard from me. Probably because I was off dealing with Hurricane Irma, 60 hours without grid power, cleaning up my yard for two days, and processing avocados.
Technically, I have one of the smaller arrays at only 4.4kW (twenty 220W panels). For backup power, I have a 5,500W (big box store) gas generator.
When the power eventually went out (Sunday at 4:40PM), we quickly dumped the food from the side-by-side freezer and fridge into the Engel MT-60 and MT-27 refrigerated chest coolers respectively. Both units were pre-chilled on 120V power, until the grid dropped out. Prior to the storm, our neighbor offered us an outlet for an extension cord (12AWG) off the inverter he was running from his Ford Powerstroke parked in front of his garage. My kill-a-watt said the output was a square wave inverter, but the conversion system in the Engel refrigerators didn't seem to care. The two Engel units were drawing a peak combined of under 150W. The neighbor's quiet backup system lasted until one of the leads to the battery off the neighbor's truck came loose in the middle of the storm, which was sometime in the middle of the first night. Monday morning, I pulled out our trusty 5.5kW generator (bought after Hurricane Frances in 2004) that I had last used after Hurricane Wilma in 2005. I started by disassembling the carburetor after sitting for 12 years. There was minor varnish in the float bowl (it was drained of fuel and run until it stalled out, prior to leaving it sit in the garage for 12 years), so I carried the carburetor over to my father's house to use his compressor to blow the tar out of the passages. (Dad's got an Onan in his Winnebago, so he had power for tools, you just had to pick what you wanted to run) My 5.5kW generator spent a good portion (75%) of the next 48 hours running a consistent 1.8kW-2.2kW load. That load was the main side-by-side fridge, the two Engel refrigerated coolers, a 12,000Btu roll around single hose A/C unit, and an occasional load of laundry through the Samsung front load washer. I used my TED 5000 to keep track of current/wattage drawn off the generator.
Just a few hours prior to losing power, I had turned up the hot water heater, and it was up to 137°F when the grid failed. It was only 117° when the grid returned 60 hours later... That was after a few showers from the wife and I. At close to 2kW load, the gas generator burns ~0.5 gallons per hour. Our neighbors across the street had power restored Monday morning. Other people on their side of the block still didn't have power when I got home from work tonight (Friday night). It took 10 days after hurricane Frances to get power back on our side of the street, so I am familiar with how brutal it can be to live without it.
If you're wondering about the Engel refrigerated coolers: my thought was I could run them off 12V deep cycle batteries out of one of our boats for extended periods of time if necessary, and recharge the batteries off the generator. As it turned out, it was so incredibly hot and humid the two days and nights that we were without power that my wife spent most of the time parked in front of the roll around A/C unit which only managed to get the room it was operating in down to 80°F at best. Monday night, we both slept on the terrazzo floor (without A/C) to keep cool. The 12V 0.45A PC muffin fans run off a 7Ah battery for several hours...
Thoughts in retrospect: 400W of PV panels coupled to a MPPT charge controller and a 12V battery would run the two refrigerated Engel coolers indefinitely. Making your own 120V power runs around $0.85/kWh. The 48 LED (5050 chip) panels I bought off eBay generate an incredible amount of light, if only my house had a centralized 12V wiring system to accommodate running some 12V items like fans and lights. At some point, I need to build an integrated power monitoring system into the generator or the house power inlet. And finally, I need to devise a 9V (dc) backup system for the Davis Weather Wizard III to keep track of the winds.
In the end, we are safe with NO damage to the house, despite dropping a large royal palm frond directly on the PV array in the midst of the storm. Mostly minor damage to our 5 avocado trees in the yard. We did harvest our entire crop of >100 large Luna avocados on the day before the storm. Despite giving away dozens of avocados, I now have 10+ quart sized bags of frozen avocado paste in the freezer to make guacamole for months to come. The fruit keep for weeks on the tree, but ripen within 3-5 days of being picked off the tree. This morning, my wife spent 3+ hours processing ripe avocados into frozen paste. At some points in the forecast cones it looked like we might be getting the brunt of a Cat 4 or Cat 5 storm. In the end, it came in the west coast as a Cat 3 (we are on the East Coast), and we really didn't test the 170mph wind rating on my array's attachment to the second floor roof.
