Removing old tape
EatenByLimestone
Moderator
Staff member
I have some packing tape that’s been attached to sheet metal for something like 10 years. I’ve finally been inspired to remove it.
I’ve tried acetone and goof off as solvents and scraping with a razor blade. All of them work, but slower than id like.
Is there anything else I should try before I try a random orbit sander or a propane torch?
I've found that lacquer thinner works
Also some nail polish removers Not all
I'm frankly surprised acetone didn't do it. I usually start with Goo Gone, then progress to Goof Off, and eventually Lacquer Thinner. But I thought acetone and Lacquer Thinner were nearly exchangeable, in this regard.
When all else fails... MEK! That stuff will take white off rice.
Oooh, MEK… paint stripper!
The acetone did do it, but I think the plastic of the tape kept it at the edges, so I had to fight it. Maybe a bit of sanding will cut the plastic enough that the acetone can get to the glue.
Reactions: Ashful
Paint thinner or isopropyl alcohol (>90%) would be what I would try. I think acetone evaporates too fast to really help much. Let it sit for a minute or two before scraping at it.
