Removing bricks in the back of my firebox to make room for a wood insert.
Sharkeys78
10
Quincy, MA
I'm trying to gain an extra inch in the back of my firebox to install a flush wood insert. Is it okay to remove the back row of bricks? Are there likely to be more bricks behind it or am I opening a can of worms? Would the bricks above then be unstable? Would it be better to grind the bricks back that extra inch instead of removing them?
  • [Hearth.com] Removing bricks in the back of my firebox to make room for a wood insert.
Very difficult to guess from a photo on its design/engineering, perhaps a qualified mason could best advise you on how to proceed, do and not do.
If you want to know whats behind the brick why not take a masonry bit and drill through the mortar joint. You may get an idea whats behind like hitting a void or more brick, metal etc. Even better drill a hole big enough to put an inspection camera through.
Reactions: Sharkeys78
