- Oct 3, 2007
- 1,539
I have a logsplitter that I am going to put up for sale but first I need to swap out the engine. It's a Briggs and Stratton I/C (the kind with the cast iron sleeve-totally rebuildable) so I want to put it on my new splitter. In order to seperate the pump and engine I need to remove the Lovejoy coupling from the shaft so that the pump mount will come off. The set screw on the Lovejoy just won't budge-I soaked it with PB Blaster yesterday, tapped and tapped and tapped, then soaked it overnight, tried again this morning (amazing what you find yourself doing after a baby wakes you up at 4:30 a.m. :lol
-no dice. Should I just say the hell with it and stick an EZ-Out in there? I really don't care if I ruin the coupling-they're a dime a dozen. I thought about heating it with with a torch, but the thing is covered with hydraulic oil, the gas tank is close by, and there would be no way to keep the shaft itself cool in the process-the pump mount is aluminum also which could be bad. Any ideas?
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
