D
DexterDay said:Edit... Oops
smoke show said:Head out there with a propane torch and perheat the pot, then go back in a hit the switch.
That should tell ya something. No?
DexterDay said:smoke show said:Head out there with a propane torch and perheat the pot, then go back in a hit the switch.
The voice of reason is back. :lol:
The pot has to be so full to light.. But then if its to full, now there is a Deep Layer pellets and this will actually hinder the ignition. If you fill that pot up to the half way point, it wont light because there is 3"-4" of pellets and they will just smoke.
Needs proper air to fuel ratio (on top of ignitor). He is getting air, just not enough fuel? (In my opinion).
Don, can you measure the pellet amount on start-up? Also can you post a video of a burn on Youtube? A video of it in action (10-15 minutes after start-up, so its settled in and excess fuel is burnt from start up) Maybe something can be seen from it running (airflow issues? Possible weakening combustion blower?)
If it runs fine after the first start, maybe it is just the Cold. But my mind is boggled by that. :roll:
Will measure when I get home. Results and pics between 5-7 (Parents are coming over for Dinner and bringing my Son back).
DexterDay said:The voice of reason is back. :lol:
DexterDay said:I would try opening the feed more Don. Adding pellets manually still wont solve the problem for the next owners of the stove.
The idea is to have an auto ignite stove, that can be set and forget. If I have to babysit the stove everyday, then I wouldnt want it (auto ignite models only).
You manually dumping them is not a cure. Altgough it will show you need more fuel and have to open the slider more. I wouldnt manually add much (maybe a half a handful to a handful).
smoke show said:I think he means position 3 or something like that.
He never said 3°. ;-)
smwilliamson said:Don2222 said:Hello Dexter
Please look at the pics below and tell me if that is a normal amount of startup smoke? That will tell me if the ignitor is ok.
I understand that the loop ignitor placed in a bracket next to the iron pot will create more smoke than a cartridge heater inserting heat to the pellets thru a hole in the burn pot.
That installation is not to code. You have a ventilated soffit, you need to be 3 feet from that. I understand its a shed..just sayin
Don2222 said:smwilliamson said:Don2222 said:Hello Dexter
OK, Scott
Here is the 3 feet distance! See pics.
Is that acceptable now?
Thanks Don
SmokeyTheBear said:Don2222 said:smwilliamson said:Don2222 said:Hello Dexter
OK, Scott
Thanks Don
Don,
Now how many feet of horizontal do you have?
Don2222 said:SmokeyTheBear said:Don2222 said:smwilliamson said:Don2222 said:Hello Dexter
OK, Scott
Thanks Don
Don,
3 Feet Horizontal
What Dexter sees is correct!!
From what I see. .
4’ vert = 2’
3’ horiz= 3’
2-90°‘s = 10’
15 total EVL
SmokeyTheBear said:Don2222 said:SmokeyTheBear said:Don2222 said:smwilliamson said:Don2222" date="1329856484 said:Hello Dexter
OK, Scott
Thanks Don
Don,
3 Feet Horizontal
From what I see. .
4’ vert = 2’
3’ horiz= 3’
2-90°‘s = 10’
15 total EVL
Fine, I didn't want you to correct one thing only to run afoul of the stove maker's limits.
DexterDay said:Where my Feed gate is set currently. From running on Low last night (straight through the night). I got just above a 1/2 and less than 2/3 of a cup. This is using Presto-Logs made by Lignetics. A smaller pellet like Somersets would have fed more. If my feed gate was wide open with Somersets, it would be considerably more.
But this is what its at now. And will start every time.
I thought your ignitor slot was different. But its just the wing nut missing that threw me off. Yours has a screw. They changed it to a wing nut later on I guess.
That vent may be causing a slight restriction on the flow also. I got a 15' EVL just by looking at it. I may be wrong. But I thought you said it was 4' vert inside and then it looks like you added 2', to the 1' you had after the 90°…
It may not be also. The blower could be weak. The cap might need replaced?
Can you measure the pellet feed amount. I set the glass measuring cup kinda in the pot. Leaving room on the sides so the blower could still breathe. The handle held it perfectly in place.
My Wife was shakin her head;-P
DexterDay said:Linky no worky..... ;-P
