therealdbeau
Burning Hunk
Consider the BTU value. 1 cord of oak is approx 24 million BTUs. 1 pallet (1 ton) of Bio bricks is 18 million BTUs
Okay, from the above link see that the Bio Bricks are only available in New England/New York.
Makes sense to me... that puts bio bricks at ~ 30% more expensive on a per btu basis
Based on BTU/$
2 ton bio bricks = 36 mil BTU and ~$700 = 51k BTU/$
2 ton seasoned oak = 24 mil BTU (best case scenario) and ~$400 = 60k BTU/$
It's not that far off when you look at it in this fashion. If you are buying firewood, it's not a bad deal. In my case every BTU I harvest only costs fuel/maintenance on the chainsaw plus my time. However, I might still buy some to supplement my wood since I don't have ton of seasoned wood. These are also very rough figures.
The moisture meter will be the judge.Yeah I've always assumed kiln dried meant the wood was essentially baked until absolutely dry. I'm thinking a kiln like a big oven not a plastic tent I've seen some users here use to speed up seasoning.
Running with the numbers you presented, 2 cord of Oak is 48 mil BTU, not 24. 24mil is only for one cord
Plain wood is cheaper than processed firewood. No one can argue that but it has benefits. No drying time, burns hot, no bugs. They're also to mix with non seasoned wood. Some of them like NIEL'S burn longer and gives you a longer, hotter fire.
The canawicks are pretty good tooI wish I could get Niels, but the delivery fee is too expensive. The place is 250 miles away so I'm spending $100 on fuel to pick it up or $540 for delivery of up to four pallets. It just isn't economical for me. There is a place local to me that sells Envirowood Briquettes which are comparable to the rest of the bricks. They are 6x2x4 which will be easy to load into my long narrow stove.
Canawicks can be bought in Maine but your state is so big there might not be a place close to you. Theres a place in Bangor.I don't think I could get those either. At least the Enviro Wood bricks are made here.
24 MBTU / cord of red or white oak looks like a good number....I just realized that one pallet of bricks is a ton, I misread something. Nevermind, the math really doesn't work in the favor of bricks. This is also assuming that you get the full 24 mil BTUs out of the oak, but as others have noted, it still seems a better deal to buy cord wood over the bricks.
Where is the factory at for the Liberty Bricks? It might be close enough for me to be worth it.
804)%20937-5300)I see it's a fair size facility. Google shows at least a couple hundred pallets there loaded.
