Hey guys, first I'd just like to thank everyone here for taking the time to post so much knowledge. I've learned a ton from this site that's helped me get up to speed on wood burning.
Here's where I'm at- I just moved in to my first house a few months ago after a complete renovation. Its about 1200 sqft in Sussex County NJ, so we get some decently cold winters. A few months ago we got down to -10 which is darn close to the lower limit of my heat pumps I currently use as a primary heat source, so a wood stove is a necessity at this point. I've got a nice compact layout and a decent spot for the stove in a central location. During the renovation, the whole house got a thick coat of spray foam insulation and triple pane windows. It's a really tight house now, so I take it an outside air kit is a must. Also, space is at a premium so low clearances are important. I also like the idea of a nice flush sheet metal hearth pad, so only back wall clearance and stove depth are really important to me. That led me to the Hearthstone Manchester, which should allow overnight burns and only stick out 26" from the wall in addition to being beautiful. My only hesitation is that it's a big stove, heat wise. As someone brand new to burning in something other than a fire pit, is this stove going to be too much for my small place? Or can I build a small fire in a big firebox and be okay? I see that the BK Ashford can be turned down to 12kbtu/h or so which would be just right, but its not as compact. I don't see published minimum heat output for hearthstones like I do the BK units, so would the Manchester be able to turn down that far? Anything else I'm missing?
Thanks!
Thanks!
