burntime said:Whats an extra 50 or 100 when you have to replace it? I used a farm boss for 11 years. I actually have 2 of them. You will be happy with it!
burntime said:Once you get it run a good 5 or so tanks thru it and put a more agressive chain on it. By the 5th tank it will be screaming. Mine took a good 5 to wake it up...
AlaskanRedneck said:burntime said:Once you get it run a good 5 or so tanks thru it and put a more agressive chain on it. By the 5th tank it will be screaming. Mine took a good 5 to wake it up...
Why does it take 5 tanks or so for it to scream? Engine rings seating like in a car?
BTW, I'll post a pic of my saw when I get it.
AlaskanRedneck said:So after handling the saws at the store, I decided to get the MS 250, I like it becuase it's lighter. Picked it up this afternoon and already cut about a cord of logs into rounds, split them, and stacked them in my woodshed. I like the saw so far.
smokinjay said:AlaskanRedneck said:burntime said:Once you get it run a good 5 or so tanks thru it and put a more agressive chain on it. By the 5th tank it will be screaming. Mine took a good 5 to wake it up...
yes its the rings seating.
John_M said:Redneck, my prediction is that you will you will be pleasantly startled by the balance and cutting ability of the MS250. You most likely will not be cutting any logs larger than 12" diameter on the Kenai and the MS250 will cut them all year long for many years to come. You chose a great saw.
Recently, I have been clearing out some trashy hedge rows. Much ash, apple and honeysuckle up to 6" diameter. I always choose the MS250 because it cuts all this stuff like a hairy chested beast and maneuvers like a hummingbird. The easy-2-start feature is a marvel of engineering and makes starting the saw an effortless experience. I find the Stihl reduced kickback chain cuts very effectively when the cutters are kept sharp. It didn't make sense to me to take off a perfectly good reduced kickback chain and install a full chisel. Removing a perfectly good chain seemed like a waste of money. For what it is worth, in my experience, the properly sharpened reduced kickback chain on my MS250 will cut much faster and cleaner than a not-quite properly sharpened or slightly dulled full chisel chain on my MS362. Your saw's speed and ease of cutting is determined more by your ability to keep the chain properly sharpened than with the shape of the chain's cutters.
Good luck with your new saw.
John_M
