sounds like the recoil spring is toast. You'll have to pull the recoil cover off, and look at the spring. I bet the little 'hook' on the part of the spring that latches on to the cord reel is gone.
Thanks SO, I'll give him a call tomorrow then pick it up so I can take a quick look tomorrow night. He will never use it again but if I can fix it for him he can sell it.
zap
Does the pull cord go back into the return position, or does it stay out when you pull it? If it does not stay out, the spring may not be the problem. It may be the starter pawls ( they are what catches onto the starter cup in the flywheel when you pull the cord). Let me know
