Hello All,
Need a little help or nudge. Currently thinking about a Jotul 400 or 500 (possibly even an f3). Have been doing my homework, now have to make a decision.
I have a ~1300 sf split level. Masonry fireplace on W end of home in lower level (garden level/walkout) w/ exterior chimney. I'm not a big fireplace fan, and would prefer to use the chimney to run something that will give me more in return. Not really interested in an insert. Much prefer a freestanding stove.
I plan to mount the stove on hearth, then rear vent to a tee, run a 6" liner up the entire length of the 25' chimney.
After reading several threads, It's clear that neither exterior chimney, nor rear vent configuration are ideal for draft (especially for the castine?).
I currently heat with propane, so want to supplement. I don't have a free source of wood, so will be buying (have good hardwood source). Not currently thinking about primary at this point, but the ability to supply a good deal of my heat with wood during certain times of the year would be nice.
Anyway - I originally targeted a stove in the ~30-40k btu range to be an occasional burner. Then thought something in the castine size would be the best of both worlds for me (sometimes primary). After deciding on it, then doing a little homework I realized that I could be asking for trouble by putting it in a situation without ideal draft. That turned me on to the 500 oslo. A little bigger than I'd like, but I could accommodate. Also open to the F3. Here are my questions:
With my current setup (thinking draft limits here) which stove will likely perform best? I know there are many other considerations - burn time - firebox size - heat output - but I'd like to start with which stove will perform best with my setup (since I know it's less than ideal). It also sounds like it would be smart to use an insulated liner considering this will be in an exterior chimney with a 12" clay liner. Would appreciate thoughts on that.
I should point out that I've listed only Jotul models because I have a nearby shop that I like that carries mostly jotul and VC, and I just like the Jotuls.
I know this subject has been broached several times here, but any input specific to my situation is much appreciated
