Yes that makes sense. I may haul the stove out again and seal the block off plate with some sealant. I may have been a bit sloppy installing that block off plate.
You just gave me an idea. Why couldn't I haul the insert out of the fireplace and set it into the room just like a free standing stove ? I would have to modify the front of the fire place and add a bit of pipe but I would have to do all that to install a regular free standing wood stove anyway. Maybe I'd get more radiant heat from the stove and possibly not even have to replace it. Any thoughts on this idea ?
It's on an exterior wall. Can't remember the model or brand, label is on the back side. I'm burning softwood at the moment which I'm told has been cut sept 2013 so it's about 1yr drying outside. Its takes hours to heat the house up a couple degrees which is why I'm looking to change things to get more heat. It may be that the insert is just to small. It holds 20" sticks so the fire box isn't tiny by any means. Here's some pix.That would void the UL listing of the insert and you would need to install it with all clearances for an unlisted stove. Also you would need quite a bit of r-value in the hearth as the insert is designed to sit in a masonry structure, not on combustibles.
Is that fireplace on an exterior or interior wall? What brand/model is it? What kind of wood are you burning and how long has it been seasoned? When you turn on your furnace/boiler/whatever, how long does it take to get the home warm?
![[Hearth.com] Rear flue exit VS Top flue exit [Hearth.com] Rear flue exit VS Top flue exit](https://www.hearth.com/talk/data/attachments/138/138889-39f6eac5f70689116edeb552c0b48cc6.jpg?hash=eFEV4W0z5u)
That's a lot of bricks to remove. I'd rather not do that unless I remove the whole fireplace and chimney which I've considered doing. Check out the pix above if you have time. My set up is shown in my avitar as well. It's a basic fireplace from the 70's, standard split entry home roughly 25' x 45' which is now opened up somewhat ie kitchen/dining/living room area is pretty much one big room roughly 25' x 30' I'd say, which is the area I want to heat. The bedrooms will take a long time to get warmer but they will eventually. I'm not trying to heat the basement with wood, I leave that fairly cold.Rather than do that, just try taking the surround off of it where it is at.
When it is at an exterior wall you may loose heat through the bricks out the back. If you have some room, try insulating behind the insert. See this thread: https://www.hearth.com/talk/threads/finally-got-around-to-insulating-my-fireplace.75755/
Has the wood been split after cutting or was it just split recently? Unsplit wood barely dries, you may be burning green wood. Did you check its moisture content? If it was split: In my experience softwood likes to soak up water. Has the wood been top-covered during the seasoning?
How far do you reduce the air when you burn the wood? Do you have a way of measuring the temps of the insert (stove thermometer)?
The surround is the black metal plate that covers the fireplace opening. When you remove that one you will see the insert sitting in the fireplace.
That is what I was going to recommend, insulating the entire firebox as it sounds like you are losing heat to the outside with an exterior fireplace, I would at a minimum insulate the firebox behind the insert with Roxul, but Roxul and Cement board works better. I saw a difference in my burn times and heat coming out of the insert after insulating the entire firebox.
Just think about it, all that heat has to warm the surrounding brick before it will start putting it out via the fan.
Smoke from the chimney indicates wet wood. You should only see some during the startup phase, like the first 10 minutes of a burn. Leaving the door open means you operated the insert as a fireplace; essentially sending most/all of the heat up the chimney. I would get a stove thermometer to check if you even get the insert up to temp. Invest also in a moisture meter to check your wood. I have the feeling you are having still wet wood and to compensate for that you leave the air open too far sending most of the heat up the chimney. Your insert may rarely reach optimal burning temps and therefore cannot heat your home.
I left it open about a 1/4" , not much but I hear what you're saying. I shouldn't have to leave it open at all if the wood is dry, in fact I should be able to close off the draft a bit after it's been going a while.
I will try my other load of wood and will invest in a stove thermometer if I see the same burn issues with that batch of wood.
Roughly what should the temp be at the top of my insert?
Yes, good point. I do have a convection/duct around the bottom, back and top which is used by the blower. I believe the blower pulls the air from the room, forces it around and out the top duct, heating up as it goes around the hot stove. As you say I should put the thermometer at the front where there's space. The top of my stove would definitely be much cooler I would say.The top of the insert is not the stove top. There is a convection air space below the top so readings on it would be low. Measure the stove temp on the face above the left or right side of the door. It should read about 500-600F with a good fire going.
I can tell you what I did. First, I got an IR thermometer ($30 at Harbor Freight); not just for the stove but also to check for cold spots in the house. Then I pulled off the surround of the insert, removed the top of the air channel to expose the actual stove top. That is the part where the warm air comes out in your case. For a few days I fired the insert as usual some times with the blower off, some times on. I measured the hottest spot on the stove top and then also the hottest spot on the front of the insert which in my case is directly above the door in the center. At the beginning of the burn the difference was usually ~100 F less in the front than on the top, later when the secondaries have been on for a while and the stove had settled in for a nice burn more like 50 F less. Then I put everything back together and now I know that measuring the spot in the front means 50 to 100 F less than the stove top. Thus I aim for 600 F to 650 F max at that location, translating to around 650 F to 750 F stove top depending on the stage of the burn cycle.
If you get a typical stove thermometer (Condar is preferred here) use it as BeGreen suggested. And maybe test your stove also with some kiln-dried wood from the store or some lumber scraps. Essentially any wood you know is surely dry.
![[Hearth.com] Rear flue exit VS Top flue exit [Hearth.com] Rear flue exit VS Top flue exit](https://www.hearth.com/talk/data/attachments/139/139660-220464cef2548fa6103743abcd963cf4.jpg?hash=v2BI1peVs5)
I am sorry but putting it up on bricks does not give you any r value it is very dangerous to do so and you should not do it. You need a hearth board or many layers of durarock next gen or micore of something with a given insulating value. Just air space does not work. DO NOT BURN IT THE WAY YOU ARE PROPOSING.
This is completely incorrect. 3/8" millboard is a fairly mild requirement. I think 1/2" Durock NexGen is about equivalent. You can no longer get regular Durock cement board (R value .26 per 1/2") Durock NexGen has replaced it, R=.39 per 1/2". Also note that bricks do have an R-value. Common brick is R=.45 for 2 1/4" thickness. And air is an excellent insulator. That is why it is used in an NFPA 211 wall shield.I am sorry but putting it up on bricks does not give you any r value it is very dangerous to do so and you should not do it. You need a hearth board or many layers of durarock next gen or micore of something with a given insulating value. Just air space does not work. DO NOT BURN IT THE WAY YOU ARE PROPOSING.
For more info on the millboard requirement here is a good, old discussion:
https://www.hearth.com/talk/threads/anyone-know-the-r-value-of-metal-clad-millboard.7102/
The pictures show the hearth step removed, but the fireplace hearth intact. Has that changed. The posting says, "As a test I want to install the stove outside the fireplace..." Has that changed or is the insert still going into the fireplace? If in the fireplace then the only concern is the hearth in front of it. This is helped by the 6" rise of the hearth floor above the hearth step. The ash lip and step height helps lower heat radiated downward. According to the label, the insert only requires a millboard hearth. A layer of Durock and brick should be sufficient hearth to be quite safe in this circumstance.
