Solar+Wood -
Here's my 2 cents on using my new PE Summit over the last few weeks.
2500 sq ft 2 story basement entry home - R20 walls - R40 ceilings, double glazed windows - stove on basement entry level. 30' Brick chimney in center of home for storing radiant heat.
I have yet to pack the Summit full for an overnight burn at -6 celcius. With half loads, I still have some glowing coals 4, 5, 6 7 and 8 hours later, and my gas boiler heat hasn't had to come on at night.
This stove seems to be able to move a lot of warm convection air throughout the house when cranked up and the house stays pleasantly warm, but I'm still learning to find the sweetspot to get mileage out of my wood for sustained, long, non-fiddling burns. (using Birch, Alder and Maple).
I was going to buy a BK Princess but went Summit because I wanted to store chimney exhaust heat in our large brick central chimney (the cat stoves send less heat up the flue).
If I had no backup furnace and 2500 sq. ft, I would have bought the biggest Blaze King, for the Thermostat, for the extra long controlled burns and 'set and forget' capacity, without a hesitation! My dealer (a decent guy) did a 30 hour burn test themselves with their demo stove and swears by the large BK.
I enjoy the ability to watch the dancing secondary burn on my Summit (evidently the window on a cat stove is less picturesque), the Summit's ability to pound out the heat when you need it, and it's reasonably large firebox and decent looks ... but a 5 - 6 hour real world hot to medium to low burn time seems a more realistic expectation on my wood, and does not compare to the thermostatically controlled, BKing behemoth, capable of chugging along for a couple of dozen hours as your only heat source!
IMO, if you only have one heat source and you live in an area where it stays below freezing for days on end, and you're not willing to baby sit a stove, then and you need loooonnnnggggg burn times, and the cat stoves are the proven performers there.
Hope it froze every one of those darn prairie dogs up. Well, maybe leave a few for the hawks and eagles
