Ready for possible cold winter breakdowns? - Show your Pellet Stove Spare Parts!
Not if the stove is new enough to have the capacitor?
I have 2 ignitors, a T/C, Door gasket, Ash pan gasket, and a Combustion blower for the Classic Bay.
Door gasket, ash pan gasket, combustion blower, and exhaust manifold for the Fahrenheit.
Ash pan gasket, Door gasket, Glass gasket, burn-pot (slightly bent and replaced when new), and convection blower (Siezed up/ oiled and tested after new one came and it worked. But for how long) for 10-CPM
Door gasket and glass gasket for 30-NC
I wont burn LP...... If something goes down, I am gonna fix it ASAP.
Wow, you are Ready!
i did and put it on my watched list in case it ever happens to me. i peruse every 25pvdc thread i see just in case whatever happens. :) i dont know what dry moly spray is, i assumed that spraying a lubricate (is it a lubricant?) would be of little value with the high temps.
I went overboard and bought this spare part for the wood stove ;) One can never be too prepared! I have always preferred the strike anywhere matches and it appears they are being banned??? This is a crock of $hit! Are they gonna ban fertilizer and household cleaners too because you could make a bomb with them too? Sometimes I wonder how some people can walk and breathe at the same time!
Ray
  • Ready for possible cold winter breakdowns? - Show your Pellet Stove Spare Parts!
Reactions: jtakeman
Dry Moly spray is a High Temperature spray on dry lubricant the Mike Holton recommends for the augers and auger tubes to prevent auger jams. I tried it and it works great!
where do you get it and whats the costs? maybe well worth it.
What no accelerant to help matters along and where are your spare plates and welding rig in case of burn through? You sir are woefully under prepared;sick .
In a pinch, I can light mine with a match(some gel added to the pellet). But the Mapp gas torch is just way too easy.
I tried pooks way once and scared the beans out of myself!
Reactions: raybonz
LOL I do have Super Cedars while unnecessary are a nice convenience. I have found that scoring into 6 pie wedges reliably starts the fire even with no kindling. One thing that I have found interesting is the Wiseway pellet burner "stove" and feel that this technology could catch on. If someone could produce this unit in the familiar wood stove look I think it would sell very well!
Ray
Now you have done it you are now on the governments watch list.!!!
Reactions: raybonz
WMDs available at your local WMT, who da thunk you only need a history lesson of WW1.
Thanks to those who gave all this Veterans Day and those who served to keep us safe.
When I bought my stove off of e-bay, it came with a whole extra spare stove, three spare control panels two spare combustion blowers and a convection blower. Everything was in pieces, but that is what I ended up with, after I put things together, the only stove part I had to buy was a burn pot that was missing.
I now have two working stoves, but only one is installed, I thing I'll install the spare stove in my garage.
Dave
Reactions: raybonz
Having a stash of parts is a real good thing.
We have a few items, but the best thing is three stoves on the main floor.
If one quits, just lite off another while we get parts.
The little Whit can do the job unless its real cold, the large Whit can do it any time and the Quad can heat the entire place if need be.
Have a stove in every corner. :)
I still have two viable corners that I am eyeing for another stove. :eek:
Still, having spare parts is a good plan.
Snowy
Do I dare post here? Just ordered 3k of Enviro Parts, 3k of Englander parts, 6k of venting, have about 4k in Harman parts as well as an assorted amount of misc inventory equally about 25k...I'm covered as well as about 100 other people...for the next 3 weeks.
... and what was your address again? Make and model of your alarm system? ==c
Snowy
Hi Snowy
Get a used stove cheap and fix it up for the other corner. Then if you sell it and make $$ it would be fun!
Hi Don
Actually, I was foolin a bit about the last two corners.
When I installed the two Whits back in 2009, my daughter called some serious smack on me for having three stoves upstairs.
I jokingly said, well don't get excited, I still have corners left over.
A couple weeks went by and I moved a corner table and put some tape on the floor, outlining what looked like a hearth pad and tape on the wall outlining a vent pipe location.
Haaaaaaaaaaaaaaaaaaa ha ha ha, you should have heard the howl when they came to visit again. " OMG, YOUR NOT REALLY GONNA PUT IN ANOTHER STOVE" ?????? !!!
I have considered a battery powered stove for use during power outages.
Snowy
You could put a Wiseway in each of the remaining corners they don't need power at all.
Then you could tell those that come to visit that you are also thinking of pulling the plug on the 'tricity as well since you no longer need it to run the stoves with.
Reactions: raybonz
Good idea Smokey. I talked to one of their top guys last summer just after they got their "Pellet Stove" EPA certified and now they are Rocking and Rolling! Interesting machine for only $1500 ! ! !
See their new video!
http://www.wisewaypelletstoves.com/
Reactions: raybonz
Just think of all the spare parts you will not need ;)
Ray
I got a identical harman minus the trim on CL for 440. No waiting for dealer or mail. Works nice in the garage too! Probably no part that can't be swapped in half an hour. Todays temp 19 with 20 plus wind. Global warming my a--. Second month below normal temps.
I have zero spares, I know my 25 will have no issues this year :fingers crossed:
I am having a carbon build up issue on the end of my auger tube that was never this bad though.
I might have to adjust the auger out a bit into the burn box.
With all the money in spare parts I'm starting to question the money saving and efficiency of pellet stove.
Reactions: raybonz
Well I have some spare parts on hand but luckily have never needed any. You don't need to stock any if you have a backup heat source. All stoves will at sometime break down, just like cars. Once you get into burning pellets it just drives most of us nuts when we hear the oil burner kick in so we fix our own as quickly as possible.
