As an aside, Hogwildz, what should I look for regarding the washers on my roof? Do they look cracked, or something?
Shouldn't be open anywhere... there should be a rake edge that seals the gable ends, and the manufacturer sells a closure strip to seal it on the peak and eave ends.
Metal roofs aren't common in western NY? With all that snow?
T
Yes, that is the type your looking for to avoid exposed fasteners. Not sure of this specific brand, but the slots do allow for expansion(as long as you don't crank the screws too tight). Make sure it has a warranted good finish like Kynar or similar to.
The washers will looked cracked, dry rotted, just like any other rubber/neoprene materials that weather and age. Think dry rotted tire, cracked etc. Don't mess with them unless they are real old or leaking. The underside contacting the roof surface may be ok for a while longer. Make sure you replace then with a a good zinc coated or s.s. screw w/ new washers. Last hing you want is cheap screws that break off.As an aside, Hogwildz, what should I look for regarding the washers on my roof? Do they look cracked, or something?
20 years is fairly old. But does not necessarily mean they are spent. Depends on sun exposure, weather etc. Look a few over over a few areas of the roof.Thanks much. I can inspect some through a window overlooking a porch. How old would be "real old"? 20 years?
I promised myself last week that I would sit on my roof and drink a Scotch when it was done, and tonight I did just that. 5 days of work for two guys so far, and I still have to put in all the alternate row screws (about 900 more to do), but if it rains I don't have to worry any more.
So are you stripping it first or going on top?
i did the metal roof on my mobile home and addition....i LOVE the sound of the rain on my bedroom roof...like a lullaby for a baby...also, i love the fact that its not very often that i have to use a roof rake in the winter anymore.
Ah yes . . . the roof rake . . . one tool I am hoping to not use that often after the roof is done.
