chuck172 said:I really can't estimate how much oil I used just for Hot Water. We have a 40 gallon superstor. We do use the whirlpool tub allot.
Can't compare the heat. It's 34* out now, I have the wood stove going. My wife is complaining that the house is cold. I have next years wood under a tarp. I might have to steal some.
With the Tarm the whole house is nice and warm, the floor is warm, the basement is warm. With the woodstove, we bake in the living room and freeze everywhere else. Also with the woodstove, heat has a tough time making it to my daughters room, she uses an electric blanket and an electric wall panel heater.
How much oil was used previously for both hot water and heat? Is the goal to virtually eliminate the oil by burning wood in the Tarm? I assume this is the case, so we could come up with a close approximation of the wood needed by adding the 5 cords burned previously in the woodstove to whatever amount of heat was previously produced by oil, converted to cords of wood.
Your comment about the bedrooms being cool with the woodstove reinforces my previous point. With the Tarm you will be heating the entire house to a higher temp. than you did before... The good news is this means you will be much more comfortable, have better control etc. etc. The bad news is this means more wood, notwithstanding the efficiency differences between the stove and the Tarm.
