I think a 350F thermometer reading sounds good for what I would call "medium-high" burn. Obviously my stove is different from yours, but that's quite reasonable; stovepipe temps hitting 400F 12-18" past the stove usually only happen when my stove has opened the gates of hell and gone nuclear on me.So I should be running the stove at 350F right?
We collected it this August and September, some of it is still rather wet
Agreed. I think if you guys are getting into the hang of burning a mix, that is ideal, moreover you should sweep the chimney often - like once a month or 2 tops, since it's likely you're generating some serious creosote with that wood.Oh no the wood is definitely not dried for a yearWe collected it this August and September, some of it is still rather wet
I honestly think my stove is just not very good at burning wood. It only lasts for an hour or two at most before it's completely incinerated, and it rarely gets above 350, if ever. I'm usually refilling the stove like once an hour or so with extra wood - so a full load really only goes for an hour or two at most. Obviously bad, compared to what I've read from others here on this thread.
It's still better than wasting a bunch of coal on warm days, but I wish they had built a hole in the top and bottom. That way, we could shut the bottom air feed when burning wood, or shut the top air when burning coal. That seems logical to me but obviously the manufacterers wanted to sell both wood and coal stoves.
IDK how to melt through steel in order to make a top hole, but I'm pretty sure it would void the warranty![]()
Sounds like you are getting way too much air intake in your stove. Is there anywhere it could be sealed up? How are your gaskets? I know nothing about coal stoves so I'm affraid I cannot help too much.
) - I can try the same amount of wood with half open damper and see if I can still get the same temperatures.
) and got the whole house up to 80F.
6 cords here ,2100 sq for two story. That was based on last winter which was almost six months here. So average 1 cord a month. I also have electric forced air heat and can confirm $600 bill for heat in the middle of winter so wood is aHow many chords of wood do people here usually go through during an average winter? Is it like 2 chords a month?
I thought that I should increase air intake until the stove hit 350F?
I'll have a couple days coming up with somewhat normal november weather (in mid december) - I can try the same amount of wood with half open damper and see if I can still get the same temperatures.
I burned like three armfuls of wood today (I don't have very big arms, and I'm not very strong) and got the whole house up to 80F.
I say that because you are burning through your wood so quickly. The only time I have experienced fast burn times like that was when my ash pan door would not seal and the air was just pouring in.
No brainer for me
So approx 4 cords. Nobody talks in face cords, stove cords only full cords lolI
I burn 10 - 12 face cords from October - April.
A thermometer on single-wall pipe should go over 500 pretty easy with the bypass open on a fresh load of dry wood. Not that you want to see it that high most of the time...could damage the pipe. I'm just saying the fact that you aren't seeing much over 350 no matter what, indicates that the wood is wet. Will be interesting to see how hot the thermo reads with some coal in there.Wet, poorly seasoned wood is a royal pain to burn and gives off poor heat. That's why you need so much air for the fire. Go to the store and pick up a bundle of firewood and try that out. Or add some untreated 2 x 4 cut offs to the wood to help it burn better.
Hi,
We have a harman mark III stove, and I burn a mixture of wood and coal most of the time (it's just so warm outside right now that I cannot ethically burn coal - it would be such a waste). I just wanted to post a picture of our setup, it's the stove, with two makeshift fans, and an outside air vent - you can also see the bucket of coal and a pile of pine wood.
This is not going to win any award for clenliness, but it has so far kept our 2000 sq foot house in the mid 70s.
I only feel terrible because I've burned like 1/2-1/3 of a chord of wood, and like 1/4 of a ton of coal already, and it's only in the mid 40s during the day
Please let me know your thoughts and suggestions.
http://imgur.com/6j56X0V
I'm with you Smokey. 4 pages of responses to an image that was likely just found on the imgur website. I'll just have to ride this one out and see what happens.Definitely punking us. Outstanding!
Nothing phony about my avatar.
Her grammar does seem pretty good for a youngster, in fits and starts. But a fake avatar? I don't think so. Appears to be a pretty average-looking young woman, all told. Maybe the knockouts up there in NH are a little sparse?Its hysterical how many responded
There was a bonafide hottie who posted here a while back. Too bad we can't put some money down to make all this conjecture interesting. Heheh. Oops, we're off topic again; Countdown to lockdown on this thread.
Can you get on the roof pretty easily? You could just look down there with a powerful flashlight and get a pretty good idea of what's going on.The only other thing I think I have to try here is to open up the pipe and see how much creasole (is that the stuff?) has built up in the chimney. Any suggestions on how to do this?
If it's cheaper than letting the furnace come on, after your fuel costs, I guess it's working.he thought maybe it would be OK to cut another hole in the ceiling and set it up with a fan....With all 4 fans (the blower fan, the register booster fan, and the other 2 fans going most of the time) it cost my dad an extra $40 a month - and we also started leaving the outside lights on 24/7 - so the cost of these fans is pretty small.
