Oldhippie
- Dec 18, 2011
- 570
Huntindog1 said:Not sure about your situation but most of these front loading firebrick lined burn tubes in the top epa certified stoves, its basically getting part of your load of wood off hot coals so you can load all the way to the bottom of the stove. Loading all the way to the bottom I can get 3 medium sized splits instead of just 2 splits if they were raised up on the coals. Plus by the wood not being on hot coals that wood wont be burning for a while , your basically getting the front of the stove burning then it will burn its way back to the back of the stove but that will take some time and this will increase your burn times. Plus some people are worried about the stove getting too hot as if you load all the wood on hot coals the thing takes off and can be burning much more wood all at one time and could possible create an over fire condition.
Got it! I'm going to give that a try, my airflow is different, so it might not work the same, but.. I might even look in the manual and see what they say.
