Looking for input from those who live in a raised ranch/split entry. We are buying a home with electric baseboard heat in Massachusetts. Can't imagine that electric bill! We want to heat with wood (and the acreage we are getting is full of oak and other hardwoods, so we have the fuel).
Architecturally, the house is called a raised ranch here in MA, but also called a split entry/split foyer elsewhere. When you walk in the front door, you are on a small landing and have a choice of going up or down 7 stairs. The upper level is 1400 sq. ft. and has living room with cathedral ceiling and fireplace, DR, kitchen, 3 beds, 2 baths. Lower level is about 800 square feet (two car garage takes up the rest) and has large open rec room , 4th bedroom, 3rd bathroom, and laundry room. Both levels of the house will be used on a daily basis; I work from home so the lower level will be my office.
There is currently a wood stove in the lower level rec room FP, sitting on a raised brick hearth.
Would it be wise to have two stoves, one on each floor? Or will we melt?
I get the physics of heat rising. The stair well is open and we do plan on putting a ceiling fan (running slowly in winter mode) at the top of the stairs and cathedral ceiling. However, I have a hard time believing one stove in the basement can heat the far south end of the upper level where the bedrooms are (the basement stove is on the north wall, so the heat would need to move 20 feet across the basement rec room, up the stairs, and down a 10 foot hallway to reach the master bedroom door).
Anyone have experience or advice?
Thanks!
Thanks!
mostly because of the garage door in the basement and the garage area isn't sealed from the rest of the basement (that's going to change this summer).
