- May 16, 2007
- 59
LLigetfa said:The pics wouldn't show until I grabbed and pasted the URLs to another window by using "Quote".Oregon Fire said:Took some photos after I got done stacking them..
The stack is 24 inches deep - 8 feet long and about 4 and half feet tall... This is 2 tons - the equivalent of 2 cords of fir in a pretty tight space!![]()
I think your math is a bit off. The flats look to be 16" x 24" each so the bulk of your stack is 16 inches deep by 12 feet long with the exception of the 5 flats above the foundation wall.
hmmm... The pics work for me - and I used img tags around the path to them.
No, my numbers are correct - I just went and double checked the measurements.. They are stacked 2 flats deep - 12 inch side to 12 inch side for a total of 24 inches deep.
1. Each flat is 12 X 16 (not 16 X 24).
2. So if you look at the photo - you see 6 flats lengthwise @ 16" per flat. = 96" = 8 feet...
3. There is no foundation projection affecting the stacking - it is a cube of bricks...
They have high btu output because they are compressed and dried, having less than 6% moisture content. Again, the lack of moisture and steam to create draft makes it so you have to adjust your burning technique - open up the stove more to allow for proper draft.
We are due for a big earthquake in the NW - even with several cords of wood outside, the survivalist in me likes having a couple of months worth of fuel "extra".
jeff
