It's about time I built myself a wood shed to keep the supply dry and also consolidate some of the 15+ piles scattered across the backyard. I would like to keep this simple, basically just posts and a roof. It's out in the woods so not too concerned with aesthetics, and would prefer it blends in with the surroundings as much as possible.
Just scored some used pressure treated lumber off craigslist for free... bunch of 4x4 and 4x6 posts and some 2x10s in various lengths from 8-16'. I also have at my disposal a few old utility poles in 10-12' lengths and a few ~6" diameter straight sections of trees from around the property also in 10-12' lengths.
For the roof I have a was planning OSB or plywood covered by epdm rubber. For the floor I was thinking I'd lay down epdm as a moisture barrier, maybe an inch or two of gravel and then pallets.
I made a mockup of a 6' wide shed that's 6.5' in the back and 8' in the front, just to see how it would look from my house. I cut my wood to 16", so 6' wide would allow four rows deep with a little wiggle room. I worry too much deeper and the inside part might get punky. I know the popular approach is to season outside and move only dry wood into the shed, but not keen on moving it twice. Hoping a shallow shed with open sides and 3 years of seasoning will be sufficient. Obviously bigger is better, so thinking something like 30' or 36' long depending on post/span arrangement.
So onto the questions...
1. How far can I span between posts with doubled up 2x10s as headers? We get some snow here in NJ, but nothing crazy. I looked at some span tables but wasn't clear which ones I should be using for this roof design/load.
2. What about footings vs on grade... in central NJ so frost line is ~42", but do I care about frost heave? No biggie if this moves a little bit and I'd really rather avoid pouring concrete. Maybe somehow tie pallets to the posts to help anchor it down against the wind?
3. Thoughts on shed depth from those who have used theirs for a while?
4. Thoughts on the flooring arrangement? Figured epdm to keep the moisture from coming up, few inches of gravel to drain any surface water and then hopefully the pallets should last a bit longer. Maybe set them on PT 4x4s if I have some leftover.
5. The ground slopes about 1' every 10' down the long side. I could excavate (no thank you) or have one side taller than the other, or just have the roof follow the contour of the ground (and still slope back to shed rain). Thoughts?
![Questions on Wood Shed Build Questions on Wood Shed Build](/talk/proxy.php?image=http%3A%2F%2Fi383.photobucket.com%2Falbums%2Foo280%2Fjeffesonm%2FIMG_20150102_120752_120_zpsmtryqlcu.jpg&hash=4a35b24ba10318d5d07dfad6a7455eca)
![Questions on Wood Shed Build Questions on Wood Shed Build](/talk/proxy.php?image=http%3A%2F%2Fi383.photobucket.com%2Falbums%2Foo280%2Fjeffesonm%2FIMG_20150102_120644_419_zpsxeavsnq1.jpg&hash=a714b7083d32c0237bf221b66051018d)
![Questions on Wood Shed Build Questions on Wood Shed Build](/talk/proxy.php?image=http%3A%2F%2Fi383.photobucket.com%2Falbums%2Foo280%2Fjeffesonm%2FIMG_20150102_120633_842_zpsnmwbq6um.jpg&hash=c55601b37674beea32d08d310e329d6d)
![Questions on Wood Shed Build Questions on Wood Shed Build](/talk/proxy.php?image=http%3A%2F%2Fi383.photobucket.com%2Falbums%2Foo280%2Fjeffesonm%2FIMG_20150102_120622_260_zpsbkdo3kvb.jpg&hash=6aa4f3078dd66040f1cb4dbb41ed2085)
![Questions on Wood Shed Build Questions on Wood Shed Build](/talk/proxy.php?image=http%3A%2F%2Fi383.photobucket.com%2Falbums%2Foo280%2Fjeffesonm%2Fshed_zps836a567f.png&hash=9ebd4f00056b369a56b35d7e9d729ccb)
