Question regarding hearth
jhayes77
3
Tallahassee, FL
Hi all, first time here. I recently had my brick fireplace covered with stone but need a solution for my hearth; the issue is the fireplace is more decorative/made for Duraflame logs so it is not the standard fireplace; the maximum thickness for the hearth stone is 3/4" and I would ideally want one piece of stone since the look of tile isn't for me. The dimensions are 6'x2'. Does anyone have any suggestions? (Picture pending upload)
Is it a prefab fireplace or is it a full masonry structure
Colored polished concrete would sure look nice.
I was told that the concrete would crack if it wasn't an inch thick. Hmm...
If it is really a full masonry fireplace that hearth extension needs to be on a slab to meet code. If it is then a thin layer of high strength concrete on to will be fine. If it is not on a slab it will crack.
Is there a reason why it cant be an inch thick?
Do you have a before pic?
It does look like a ZC with refractory bricks.
  • Question regarding hearth
Yes that is my thought. And most have air vents around them which can't be restricted. It looks like they may have been in this case which would make the unit unsafe.
On the other hand I may be completely wrong it could be perfectly fine but I felt the need to check
Reactions: SpaceBus
