I have a Leyden freestanding stove that is connected to a T in the rear and then vented up (inside existing prefab flue) 25ft using a 4" ForeverFlex liner to the top cap.
It looks to me that the installers inserted the 4" T horizontal section "INSIDE" the 4" Leyden vent opening in the rear and then wrapped black painted aluminum tape around it. This doesn't seem right to me. Doesn't all vent pipe or even house septic drains insert INTO the next piece so there is no leakage?
It seems to me that the T adapter should have had one end piece adapter that went OVER the 4" vent output on the stove and then INTO the 4" T horizontal piece.
Am I correct in assuming this?
If so, How do i fix this and what sort of part (DuraVent?) do I need that can go OVER the stove 4" output and then INTO the 4" T adapter horizontal section? I plan on moving out my stove 2-4 inches from where it is because there isn't even enough room in the rear to get a stubby screw driver in the back to take off the rear panel. So if I add an adapter it would work out fine.
Also, the T inserts INTO the foreverFlex liner at the top and that seam is wrapped with aluminum tape, no issues there.
Feedback is really appreciated on this
Rich.
Rich.
