Question on running 6" double wall chimney pipe through roof overhang.
Roospike said:
hearthtools said:
ICC through wall and up.
I had noticed in the picture that the looks of the Boxed in chimney vs the open non-boxed chimney that the boxed in shows a vented flashing cap for the pipe and the open does not . This has come up per vented vs non vented flashing . Per the picture ........... is this the rule ?
Yes Like it showed in the vent or not vent thread.
ICC only needed to be vented in it is a moibil home or inclosed unventalated area.
What about running the pipe threw the overhang and creating a jog, if more space is needed. I think the additional carpentry work,
Would work out a lot cheaper than the elbows jog in the pipe. Another solution is to cut off the facia trim board to within 2" of the pipe on each side apply your roof flange and trim it to equal the roof line. Since combustiables have been removed and the outer flange is proctecing nothing but air I see no harm.
I stand corrected. Thank you Metal for the updated install manual. My manual was old. When did this change take effect? and does older pipe that pre dates the manual qualify for the reduced clearance?
I got the pipe today. I'm going to start installing it sometime this weekend if time allows. I think I can make it work one way or the other even if a little carpentry work is involved. I'll scope things out better and decide what I'm doing once I can get on the roof. I'm figuring on going through the overhang unless I see otherwise when I get up there....I think the current flashing will work, it may need trimmed a little however.
Buck, you might want to clarify who your talking to. Lord of fire is a description of senority, the user name is up above that. Lots of lord of fires in here :)
Yeah, I saw that after I posted and edited my post. I also read his post a few more times and now I understood what he was trying to explain.
Speaking of "Lord of fire" what are the cross over numbers for that status per posting . What is the next title after "Lord of fire" and the post count to get there ? Was Lord of fire title just added this season ?
Roo I think 500 is the next post number to lord of fire Mabe we should have a contest to determine the next heading?
