Question above Wood Stove
reveles
6
Massachusetts
Good evening,
I already have a chimney with a flue set up for a wood stove or pellet stove. I believe the previous owner of the home must have gotten rid of it. My question is, If I have someone come by and install a wood or pellet stove, any idea what the price would be around for either ? I ask this due to the fact that it appears there is already a pre-existing set up versus a brand new set up/ install.
There are way to many variables for us to give you any sort of idea. We would need tons more info
What diameter/size is the chimney? Height? Lots of variables to consider. Chimney height, firebox opening/diameters, etc.
More than 90% of wood stoves fall into a $800 - $3500 price range. Delivery and hookup can be as little as $400, if what you have is already safe and compatible, up to a few thousand, if not. All-in, it could be anywhere from $1200 - $10k, depending on your tastes and requirements.
Thank you.
