If exterior, then I would strongly consider an insulated liner. Are you sure this is an 8x8 chimney? 8x8 sounds rather small for a fireplace. If so, is that ID or OD?
There are 2 types of insulation, a wrap and a pour down. The wrap as you know is like a blanket around the liner then it is installed. The pour down is a mix that is poured around the liner after it is installed. You install the liner with nothing on it, just the liner. Block up and spots where it may leak out, so if this is for an insert, reach up into the smoke chamber and block the corners with some insulation to stop the pour down insulation from leaking out.What do you mean pouring insulation down there?
7.5" will be close to 8"s outside will that still work in your chimney? If that wont work i think a 7" will be fine.I found a 7.5" round liner from chimneylinerdepot.com. I'm going to double check my measurements when I get out of work tomorrow and go from there
Got home a little late today. Its dark out however I might just go up there.
. Thanks for all the help guys. I'm 26 and having really had any experience with a wood stove.Did you split the piece of wood first? It must be split to get an accurate reading. Put the probes in line with grain in the wood.Checked a few splits that I store in my basement breezeway and they read 17-19 %
Yes, check it in the middle. I bet it's 27% on the inside.Wood came pre-split. Should I split again and check it??
