It's a way to kinda manually control temp. In essence you are forcing the fan on all the time by never allowing the stove to achieve the temperature you set it at so it just keeps trying.
To me that means the modes are pretty much the same as I'd say 1/2 hour is within experimental error given lack of rigid experimental controls.My test is finished I made 1/2 hour less and stove Temp Auto mode with 1 bag of pellets I made 27 1/2 hours compared Temp mode in room settings the same temperature and the same conditions outside temperature
ok... but is it producing heat with the feed on #1, temp on 75, room/manual as was instructed?It's a way to kinda manually control temp. In essence you are forcing the fan on all the time by never allowing the stove to achieve the temperature you set it at so it just keeps trying.
Sure it is. But as I said, run that way you are controlling the room temp with feed rate instead of thermostat. It will also work in Room / Auto that way and you'll never cycle the igniter either because temp will never be satisfied.ok... but is it producing heat with the feed on #1, temp on 75, room/manual as was instructed?
and what speed is the dis blower set at?
ok.. understand. I think.Sure it is. But as I said, run that way you are controlling the room temp with feed rate instead of thermostat. It will also work in Room / Auto that way and you'll never cycle the igniter either because temp will never be satisfied.
"It will always be less pellet consumption with the feed rate lower.... Run it as low as you can, while still maintaining your comfort level. My feed rate is more controlling over stove output than the temperature dial will ever be. Doesn't matter if it's on room temp or stove temp. I never need go over 2 on the feed rate. Never consume more than 32-38lbs a day...
Yep. Mine operates totally differently than what everything states. I only use stove mode myself, but while documenting auger cycle times, I have found that turning up my feed rate in fact ALWAYS runs the auger cycle "ON" time longer. Stove temperature goes up as well as pellet consumption. Even if the temperature/# dial is turn down to 1.... My auger cycle does not change at all with the temp/# dial."
very interesting..
I'm using this method today even though it is completly contrary to Harmans rules of running the stove...
"lowering the feed rate is like putting a brick under your gas pedal"
is the term most used...causes unburned pellets, room never gets to temp you desire, dirty stove etc but I Imagine with the blower running constant this method works.
I know my stoves Inards so I will be doing it your way and will see if it suffers any downsides..
But Cory obviously your house is tight and very well insulated. In a house like Tony's or mine ( mine a little larger and certainly old construction, his with more glass) when the wind kicks up out of the WNW at 40+MPH and it's in the teens, single digits on down lower even, your feed rate system fails. Anything works in this shoulder season and down into the upper 20's. That's why we have P61's for that cold weather, we need fire, fire makes heat ! Otherwise we could have bought P43's, or in my case a 35i. And actually for a good part of the winter could probably have gotten away with P43's and certainly you could. Point being right now I could probably stick a propane torch in the stove for a fire and it would heat the house, it's 47 deg out.Yep. Mine operates totally differently than what everything states. I only use stove mode myself, but while documenting auger cycle times, I have found that turning up my feed rate in fact ALWAYS runs the auger cycle "ON" time longer. Stove temperature goes up as well as pellet consumption. Even if the temperature/# dial is turn down to 1.... My auger cycle does not change at all with the temp/# dial.
Correct, with all those factors, it's still irrelevant that the stove operation is still differentiating from the standard operation. I have done my testing starting with a cold home also. (58* inside, 21* outside) Multiple tests and doumentations.But Cory obviously your house is tight and very well insulated. In a house like Tony's or mine ( mine a little larger and certainly old construction, his with more glass) when the wind kicks up out of the WNW at 40+MPH and it's in the teens, single digits on down lower even, your feed rate system fails. Anything works in this shoulder season and down into the upper 20's. That's why we have P61's, we need fire, fire makes heat ! Otherwise we could have bought P43's. And actually for a good part of the winter could probably have gotten away with P43's and certainly you could. Point being right now I could probably stick a propane torch in the stove for a fire and it would heat the house, it's 47 deg out.
You have to hit a point of diminishing return if your house requires enough heat. Turn the heat up all you want but if there is no fuel it's going to run real long to recover a house, if at all. It's like too small a nozzle in an oil burner, you can actually hit a point where it runs so long to recover the house temp it uses more fuel than a bigger nozzle that recovers quickly. So I'm going to say that your house doesn't require a whole bunch or heat. Mine on the other hand ( running in room temp in cold weather unless backing up with oil) in the cold weather does best at feed rate 4ish. Even 3 will use more fuel. And it's also fuel dependent. But my average feed is around 4. In Stove Temp I run three and have run two because I'm running a fixed fire and if it's warm out the house will heat, if it's cold out the oil will kick in.Correct, with all those factors, it's still irrelevant that the stove operation is still differentiating from the standard operation. I have done my testing starting with a cold home also. (58* inside, 21* outside) Multiple tests and doumentations.
Example: Set feed rate @ 4.... Change temperature/# dial anywhere from 4 down to 1, and the auger cycle stays the same... Again, don't forget that this is stove temperature mode testing. The number dial is only supposed to increase heat output when turned up.
Correct. I realize all of this. My testing takes all factors into consideration. Nothing will change the fact that the stove outputs more heat, and more fuel consumption with the feed rate set to higher settings. I can tell you to the second, how much the auger cycle runs with each increment of the dial, down to 1/4 number intervals.You have to hit a point of diminishing return if your house requires enough heat. Turn the heat up all you want but if there is no fuel it's going to run real long to recover a house, if at all. It's like too small a nozzle in an oil burner, you can actually hit a point where it runs so long to recover the house temp it uses more fuel than a bigger nozzle that recovers quickly. So I'm going to say that your house doesn't require a whole bunch or heat. Mine on the other hand ( running in room temp in cold weather unless backing up with oil) in the cold weather does best at feed rate 4ish. Even 3 will use more fuel. And it's also fuel dependent. But my average feed is around 4. In Stove Temp I run three and have run two because I'm running a fixed fire and if it's warm out the house will heat, if it's cold out the oil will kick in.
Well I have to say you are diligent.Correct. I realize all of this. My testing takes all factors into consideration. Nothing will change the fact that the stove outputs more heat, and more fuel consumption with the feed rate set to higher settings. I can tell you to the second, how much the auger cycle runs with each increment of the dial, down to 1/4 number intervals.
I have to agree with Alternateheat..Correct. I realize all of this. My testing takes all factors into consideration. Nothing will change the fact that the stove outputs more heat, and more fuel consumption with the feed rate set to higher settings. I can tell you to the second, how much the auger cycle runs with each increment of the dial, down to 1/4 number intervals.
Tony I think jags tried this last year ( i should let him speak for himself but at the moment he isn't here so he can correct me when he is LOL) and as we got into winter he ended up with feed rates much higher and I want to say I recall something about room Temp Mode too.I have to agree with Alternateheat..
it's seems like a good pellet saving constant blower operation that is good for Shoulder season like now..
I doubt if it will work on anything other than a tight as a Baby's A... dwelling.
Can't see a feed rate of #1 giving me enough heat on those 20-30 degree or lower days..even with the blower running constant..
but I will try it just to prove myself wrong or right.
makes sense..You gotta get into Stove Temp Mode when running dual fuel. At least so around here.
yes..makes sense..
Dan
Indeed, I want to witness this first hand so may experiment too.Too warm out tonight though.Let us know the results when you do...
Dan
The hottest radiator in this house is about 8 ft away from the probe. The P61 radiates heat and so the stove is about 12 ft from the thermostat, though the thermostat is facing away in the next room . It just doesn't work in Room temp they fight each other..yes..
I assume the temp probe would always be picking up the heat from say hot water baseboards [ in my case about 4 feet below the probe] and results would be a probe always being satisfied and a stove that never fires back up " in Room/auto mode"
I was running my p61 in stove temp auto tonight actually, I just flipped it back to Room Temp and it's shutting down presently. It's 45 out now.My place is small enough that a 1/1 stove temp / auto setting gets even the bedrooms to overheating after a while even when it is 18* outside. But, that isn't the dead of winter when there is tremendous cold pressure coming into the bedroom from above and below, along with heavy winds.
When I had the Hastings, in the coldest times I ran it in the mode where it would idle unless heat was called for, but the blower always was on (unlike room temp/manual - I tried it the other night with 5/4 settings and the blower went off when temp was satisfied). The Hasting's blower would go to a lower setting while idling, but it never shut off and would go back to high when the thermostat requested heat. So, it is possible that stove temp/auto has a place in the repertoire for me. Ill just have to play around when it gets cold enough to warrant it.
