Yea, Smokey, I pulled a 'stupid' and linked to myself..........Linky no worky.
The newer one should work.
does that. I can't come up with a valid reason for the voltage to drop to zero across the power leads other than a short in the motor or the so-called hot lead is some how shunted to ground. I've seen some strange wiring over the years.I'm with you, Smokey.Don't feel bad tj I pull all kinds of stupids it goes with the territory. You know old ageitudedoes that. I can't come up with a valid reason for the voltage to drop to zero across the power leads other than a short in the motor or the so-called hot lead is some how shunted to ground. I've seen some strange wiring over the years.
What was the voltage on the gate? (the third pin)Hey guys,
I made a mistake following the etches from pin 11. It does not go to the coil, it goes to the a resistor and Q5. I measure the voltage on the input to Q5 I get 120AC I measure the center pin which goes to the fan (pin 11) I get 0 with the snap disc jumped. Looks like a bad component.
! You don't want to buy a new one for your buddy too
Chevy55, I have a Santa Fe as well and have experienced a similar problem recently. I am not as electrically savvy as it appears you are but I have checked current at the snap discs and have reading there. I just pulled my auger motor and did the same as you did by hooking up a direct power cord to the red and black wires. All that the motor did was make some odd noise and jerk a little but no spinning. How did your auger react when you did this? Does it sound like this is a bad motor?
Thanks for any help you guys can provide.
It sounds like you actually did what B-Mod and I did a couple of years ago but just in a little different fashion, 55Chev. Your convection fan always runs in high then, just as ours do, right? In my case, I got my 120 volts from the output side of the safety snap disc #3 so I have both the fuse AND the protection of an overfire condition afforded by the snap disk #3. You might want to change that just for safety's sake. Otherwise, It's nice to see you back. I've enjoyed your digging into the control board and have earmarked all that info. Like you, I wish we had a schematic of the box. I'm sure it's pretty 'caveman' logic in there!
We jumped the voltage so that even if we run the stove on LOW, the convection fan will run on high to get the most turbulent flow through the tubes that we've put springs into to increase the surface area and create the most heat transfer.Yep, always runs on high. I always had it set on high anyway. Why did you guys jump the voltage?
It was kind of fun digging in to the circuits. I was an electrical engineer for many years designing circuit boards for computers. Back when it took a whole circuit board to run a disk drive. It has been a long time since I did any debugging so it brought back a lot of old memories. I am a program manager for the Air Force so they don't let me get to close to any logic or test equipment.
I did look up some of the components on the board and it does seem like a very simple logic. Even and old engineer could follow if he had a schematic. If you think about it there is really no much to it. With the Snap discs for protection the control board only has to control the feed (both start up and on going), turn th igniter on and off, and last sense if the fire started within a period of time.
I don't monitor the site a lot but if I see an alert I will respond. I appreciate all the help you guys gave me.
Hey guys,
when I jumped the auger motor it did turn so it sounds like you found your problem. Mine turned smoothly at a fairly slow pace Like I would have expected.
For the guys that helped me (over and over) with my problem I apologize for not letting them know the outcome. Probably because I cheated and was a little embarrassed. I did replace the Triacs and still no power to the recirculating fan. So here is the cheating part, I soldered a jumper between 120 AC input pin on the control board to the pin that goes to the snap disc for the recirculating fan. Since I was going to replace the board anyway I had nothing to lose. This works fine with the only concern being that the 120AC is always at the snap disc even when the stove is idle. The fuse is still in the circuit so if there was a problem you have protection. Probably not a recommended fix and I do plan on doing some more research when the weather is warmer and I do not need the stove. if I can find a schematic for the board It would be very helpful. Otherwise I am just shotgunning compontents
By getting a reading on the snap disc, I'm assuming that if you were on ohms that it went to zero across the terminals when you put a vacuum on it. That rules out the vacuum switch and snap disc #2. Now you have to find out why there's not enough vacuum to close the switch. What heat setting are you using? Try it on HIGH for most vacuum. Make sure dump gate on bottom of burn pot is fully closed and is not hanging down (take out ash pan and look). Check door gasket with a dollar bill. It should show significant drag as you pull it out after closing the door. Make sure that the combustion fan turns freely by hand and you don't feel any resistance which would indicate a buildup of ash in that little chamber where it sits.
!! WTF did I move down here for???That's great news that you got it going! You are talking to a group of boneheads because we have ALL done stupid stuff, whether we want to admit it or not. Yep, without pellets you won't get enough vacuum to close the switch, especially on LOW. I discovered that and posted about it a couple of years ago. I guess I was troubleshooting a problem and hooked up a meter to the vacuum switch.
Stay warm. 7 degrees here in GEORGIA!! WTF did I move down here for???
