Hope so, Easy fix then. kapThanks bunches. I'll report back when I get the new fan installed and pipe recleaned. Betcha I'll find a buildup.
Usually when they ship those exhaust fans, they are on the housing. They do that for shipping purposes. You should only need the fan and gasket, not the housing. kap
Ya, just take fan off of housing by loosening those 6 screws that screw it to housing and twisting from slots to the openings in round flangeOh, that's why the new one looks different. Didn't know why.
Stove is unplugged, I'll double-check, triple-check it's unplugged before starting.
There shouldn't be any creosote.
It's half way up the auger tube, KapSounds like everything is running, but she needs to find that #2 snap disc on the drop chute. Trying to remember if they combined #2 and #3 together at one point. Where is your #3 tj?
With your exhaust clogged (very likely) you aren't getting enough oxygen to the burning pellets and you could very well be generating a lot of creosote right in the burn pot, which drips out the holes and down onto the igniter.Not even from a bad burn? It's dark black and goopy, like tar.
Could be the pellets. They may be old, as we're still using last years. Never had a problem with them before, they don't give much ash and clinkers are rare.
As to the #2 snap disk, it's not where you see it in the video. Unplug the stove and put your hand on the back side of the chute that the pellets slide down. You'll feel it back there.
If those wires are orange and one runs to the vacuum switch, then look no further. That's where #2 is hiding.I see 2 wires heading in that direction, but can't get in there deep enough to feel it. I might have to take the left door off to get to it (not enough clearance with the door hitting the wall.)
With the fan sitting up, lay the gasket in place on top of the flange, push a screw up through the hole and gasket and punch it through a small piece of paper or thin cardboard. That will hold each screw in place. The paper might char on the first burn but no big deal. You could also put the paper on the screws and THEN PUT THE GASKET IN PLACE to insulate the paper if that worries you.i'm curious what other people do as far as fitting the gasket. thread the screws through or leave the screws in and press the gasket over them?
i was using a hand made gasket, so maybe the holes were bigger than what comes from the suppliers.
i just don't want to give bad advice. it actually seemed a little less stress on it pressing it on since it was never left hanging from one or two screws at the beginning.
i'm also assuming the screw heads are the same small size, but it's possible that they aren't always. use your best judgement.
That's exactly rightOne is orange, one is red, but they both connect to the vacuum switch. Phew. So glad I do have all my snap discs. I've been so confused about those, for years!
