whit said:SmokeyTheBear said:Remember some of the quads have auger motors that have funny habits like running backwards and switching directions. That capacitor appears to be the hallmark of such things. Make certain your manuals are for the correct stove.
What two wires can screw up pales compared to 4 plus an additional device. What ever happened to KISS?
Okay, the augur motor works. Putting live current on the white and black pins of the unplugged line starts it. (And also is a significant shock-or-short danger, but I got away with it.)
Does that pretty much mean I'm looking at a control box gone bad, or is there still a possibility that it's snap disc #2 or something else?
Looking more closely, the incoming plug just has three lines - two white on the same plug pin and the black. Then the plug on the motor side has to capacitor over to a red line from the black, possibly to give it an extra jolt to start? No matter. It can start. So the question is why it's not being asked to.
Looking at the print Power comes from the vacuum switch then it goes to the snap disk 2. From there to the auger. You need to trace the path before you can look at the control box. I'm betting its snap disk 2.
But I would jump the vacuum switch and snap disc 2. See if it works. Then plug back in the vacuum switch and see if it still works. If it does the vac switch is good. and snap disc 2 is at fault. Looking at the parts snap disk 2 is supposed to be auto reseting(not sure on all stoves though) if it isn't there is a red button tj was mentioning. push that and reconnect the snap disc.
Another tip is sometimes you need to tap these discs or heck it could also just be a loose connection! You might be able to put it all back together and away it goes!
