light on = circut closed. so thats that. and i assume for test purposes you are turning the thermostat all the way up.
Check that control board.
BeGreen said:MSG's the man. The vacuum switch itself could fail also or could have a disconnected or crimped hose.
Tacoma, are you in Tacoma, WA? or is that your Toyota handle?
BGtacoma245 said:I do not have the log kit nor outside air. Venting is just a 45 degree straight out to a horizontal cap. Thermostat hasn't been changed. I did notice that the flame seems to get a bit larger than normal just before the auger stops feeding. Maybe 8 inches off the pot.
