Those tubes are coated with creosote! I only see that if I run the stoves for a long time on low. You definitely are not getting enough combustion air to get a proper hot burn. Are you sure that all 8 of the SMALL holes at the bottom of the burn pot are open? 4 at the base of the slanted part and 4 around the front of the burnpot at the bottom. I use a bent .38 caliber pistol wire brush to keep them open. Of course, the pot has to be cool to do this. I do it at the end of my weekly cleaning.
Yes, one thing that Quad has never seen fit to do is have a properly designed shoulder bolt to hold the burnpot gate at the proper tightness. They just put a nut and bolt on there and tighten it up. You can, as someone said, just loosen it a little until it moves easily. Just don't get it so loose that it sags down. The accepted maximum is to have the side of the gate opposite the pivot to have no more gap than the thickness of a dime. We try to keep it less than that. Once set, I haven't had to adjust mine in 4 years. Loosen it up a little.
