Hrmm I don't know anything about your problems with the Defiant, but I wouldn't be surprised, however the Defiants as far as I know require a 8 inch liner and yours is a 6 inch. Most larger stoves should be run on a 8 inch liner and usually have direct specifications as such.
Not sure if any of your current problems could be related to liner size...
Yea, I think the princess is pretty big as well and is ok with a 6in if i remember correct, but larger stoves like the buck, king, and defiant are 8 inch liners.
Just commenting that his VC is delineated as needing a 8 inch liner..
The quad will never perform as well as a bk. The specifications tell you that even under ideal conditions you will have lower efficiency and shorter burn times. A well operated quad will surely outperform a crippled bk though.
This may have changed but when I had a Quad pellet insert their customer service was excellent. I emailed or spoke with them several times and they were very helpful.
Like what?There's more to performance than 24 hour burn times and dirty viewing windows.![]()
Like what?
Efficiency, bk is #1 in the world.
Control, bk has a stat and a cat that allow a huge spread from high to low.
The bk looks bad, agreed, but spec for spec nothing matches up. I own a good noncat, there's a place for that kind of burn cycle out in a barn.
Like what?
The barn is the only place my wife would allow the BK. I'm happy you like your stove. My stove heats my castle just fine and has great fire tv.
Wow! Now THAT'S UGLY!! Were that to wind up in or anywhere near our house, my wife would move out.
Your central heating unit is prettier?
