Quad classic bay no power. Need help finding snap disk 3.
GenghisJon
74
Middletown, CT
No power and I'm ready to try resetting snap disk 3.
Can someone please help me find it?
I'm a newbie with this stuff so be patient.
Thank you in advance
Quad classic bay no power. Need help finding snap disk 3. if you open the right side access door, remove the triangle shaped access panel. under the auger .
Have you checked the main fuse? Don't forget to check the input line on the bottom right too. Maybe control board worked its way loose ? Good luck with her.
Snap Disc #3 (Burn Back Protector) 250°F
Snap disc #3 is mounted on the right side of the auger tube. your stove is an insert and mine is free standing access looks a little dif but follow the grey wires from you control box and the will take you to #3 snap disk
Hows the fuse?
Try removing the feed motor cover, in the hopper. Should be right there. Some have a reset button, some don't. kap
Is this the feed motor cover in image 1 below?
Anyone have experience taking this off, not sure what tool is required.
  • Quad classic bay no power. Need help finding snap disk 3.
Is that on the front ramp of the hopper? Ive never seen one riveted, usuallt philips screws hold it on.
Empty the hopper, put a few paper towels in the bottom of the hopper. Drill out the rivet’s. Take off cover reset snap disc (if its resetable). Put cover back on put sheet metal screws in place of rivet’s, pick up paper towels and vacumm out hopper to get residual metal shavings. Refill hopper with pellets fire up the stove.
Reactions: stovelark
Bump to see if somwone can help me find snapdisk 3 on an classic bay insert.
Thanks.
Under auger motor cover in hopper. Right at bottom of where covering stopped. You'll see two wires with a reset button in centre
