For a Castile, it should be flashing 6 times in a row, not 4. There should be a dial on the control box that can be turned to change the setting. Unplug first.
tjnamtiw said:For a Castile, it should be flashing 6 times in a row, not 4. There should be a dial on the control box that can be turned to change the setting. Unplug first.
DannMarr said:Mine also flashes four. My insert is from 2002. What does that screw do? and which way do you turn to do what?
solved problemThe owner has tried a new auger motor and control board with the same outcome.
1. The auger motor was dead. 2. The control board would not send power to the vacuum switch to control the auger motor.
after suggestion to check voltage againWe then started checking for voltage and we intermittently had 115v at the vaccum and snapdisk switches, but it would drop to 85v and sometimes to 2v.
umped them one at a time and then both at the same time, but that doesn’t matter if yu’re not getting power to the red wire on the vacuum switch. No power there no power ot the snap disk or the auger.
DannMarr said:Original problemafter suggestion to check voltage againWe then started checking for voltage and we intermittently had 115v at the vaccum and snapdisk switches, but it would drop to 85v and sometimes to 2v.umped them one at a time and then both at the same time, but that doesn’t matter if yu’re not getting power to the red wire on the vacuum switch. No power there no power ot the snap disk or the auger.
?????????????????????????? hh:
It's hard to help when the information given is inconsistant.
Glad it worked out in the end, enjoy!
AZ Pellet Guy said:rapi
Do you think you will tackle another stove repair.
I bet it is a good feeling to solve the problem, glade you stuck it out.
