Nash’s said:My vertical bracket's are cut just above the stove and lock washers and wing nuts allow it to pivot straight above the stove. It stays in place above with just a compression fit i.e the bracket's are the same width as the duct and the hangers have just enough side to side flex to allow the box to fit and stay nice and snug. Best part is its a one man gig...don't need anyone there to hold anything
Thanks for your comments
Thanks for the pics Jeff. That is an interesting approach. I installed a Y pipe further down in my ductwork to branch to the two registers. In the Y pipe I installed 2 dampers to control air flow to each room. See 1st pic.
Also the home depot fan you put into the ductwork works great!! see pic 2
Register temp is 150 degrees F when stove is set to 3 See pic 3
So I got one swing away pipe hooked to the stove. See pic 4
There is a rope around the yellow pole so I can swing the pipe away and tie it to the pole and then open the door for cleaning!
Speed control and fan switch. (Top switch connects fan to Thermostat, bottom switch turns fan on manually) See pic 5
