perplexed said:Okay- Here I go again . If I do not get this after it has been spelled out so clearly for me I officially give up. Just too much for my brain to get![[ guote ]Success is measured in small steps. [/guote]
When the spaces are removed, this will be rendered as
[guote]Success is measured in small steps.[/guote]
Perplexed,
What "spaces" are you referring to when you say "When the spaces are removed, this will be rendered as"?
I'm quoting your entire post and changing the "q" in any quote brackets on the quotations you created to a "g" so you can see what it looked like before you hit "submit".
You'll see that you have an extra "[" in one spot and an inserted "space" in front of the "]" in another (although I don't know that the extra space actually hurts anything). This is probably because you were creating them from scratch so formatting errors are easy to make but it isn't hard to get it wrong when editing an existing quote.
If you clean it up a little it looks like this (with the "g" in the quotes turned back into "q")
Hope this helps.
~Cath
ETA, I think I figured out what you meant by the spaces you deleted. It looks like those particular spaces aren't critical because once you correct the extra "]" in the first version it then looks pretty much like the second one.
??? you get that 30 hooked up yet bro?????
