CharlieTuna
Insulation doesn't add that much cost to a liner...$300 maybe, even if a little more, that is pretty cheap insurance to know your good to go on the clearance to combustibles (CTC) around the chimney...plus the chimney will perform better on a modern stove, especially a cat stove like you are looking at...they can have very low flue temps at times...tend to work poorly on a clay flue many times. Insulated liners stay cleaner, and for longer too.
It would be foolish to install a new liner without insulation in my opinion...UNLESS, it was a flue of the appropriate size (most are over sized for modern appliances), internal to the house, AND able to verify the CTC for the full height of the chimney...which is almost impossible to do without tearing into the walls on many/most houses...
Ah, this is for a cat system? We had one and I always disliked it compared to what it replaced. When it died. I made sure not to get another one. The cat system requires more maintenance. Dealers love them for the service contracts they can sell. They don't actually burn off the creosote, and therefore require that heat be wasted up the chimney to keep the creosote from precipitating in the chimney. Thanks for explaining that to everyone. When the cat gets fouled it smokes and the neighbors can complain about it. More reason not to get one. Hopefully, it's not too late for the OP to change his mind.
